Page 20 of 34 FirstFirst ... 101112131415161718192021222324252627282930 ... LastLast
Results 191 to 200 of 337
Like Tree1Likes
Thread: DAB DAB+ FM Digital Radio Development Board
  1. #191
    Raw Wave SNOtwistR's Avatar
    Nov 2009
    Keswick,On Canada
    While testing the monkeyboard unit with Driveline, I was using just the included antenna and it worked fine in Canada for the FM. SNO
  2. #192
    FLAC Mickz's Avatar
    Sep 2009
    Australia
    The supplied aerial is fine for FM reception in a vehicle unless you have interference from some part of the car-pc that is desensitizing FM reception. DAB is usually effected more than FM in this case. For fringe area DAB reception an amplified DAB aerial makes a noticeable difference. Because of the higher frequency involved in DAB reception, the quality of the DAB aerial and it's cabling are critical to ensure usable reception.
    Palm sized ainol MiniPC, 8" Transreflective PRO, Win10, Reverse camera, Dual 10HZ GPS RX's for Speed Display & Sat Nav, FM-DAB & Phone Modules, iDrive interface. T-Screen HVAC control, custom microcontrollers, microcode and FE.
  3. #193
    Mar 2010
    Moving the radio to the boot and using six inch cables with a heavy ferrite has got rid of the hum and improved the signal quite a lot (with the supplied antenna), I still think I'll be investing in an external DAB antenna though.
  4. #194
    FLAC Mickz's Avatar
    Sep 2009
    Australia
    If signal reception improved with ferrite beads then it's almost always the result of RF noise coming from the PC / PSU. I noticed a substantial improvement in DAB and FM reception with my external (amplified) DAB-FM aerial. Another thing to try is grounding the aerial cable shield to the chassis about 6" from the DAB module, this removes RF noise from the outside of the cable and stops it coupling into the DAB-FM module's front-end via the module's ground return path.
  5. #195
    FLAC Mickz's Avatar
    Sep 2009
    Australia
    Just a quick teaser, JP from MonkeyBoard contacted me about his new module -- Just to let you know that we have made new boards with the KeyStone 8650 module coming in next week. This module supports SlideShow. The new board will be AUD86, and CarTFT in Germany, and Cool Components UK will be the first two companies to carry them. He is currently working on the EPG code.
    I was lucky enough to get hold of a test unit and have modified my app for the new board, here is a picture of it running.
  6. #196
    FLAC Mickz's Avatar
    Sep 2009
    Australia
  7. #197
    ibf
    ibf is online now
    Oct 2010
    Very nice, I will be getting one for sure.
  8. #198
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    Fantastic new version, I love it !!! What is the price of this new version ?
  9. #199
    FLAC Mickz's Avatar
    Sep 2009
    Australia
    Quote Originally Posted by pierrotm777 View Post
    JP said the new board will be AUD $86, and CarTFT in Germany, and Cool Components UK will be the first two companies to carry them
    BTW the new board looks exactly the same as the old one.
  10. #200
    May 2006
    Is there a new API from this one?
    http://www.cartft.com/support_db/sup...amming_API.pdf
  1. Replies: 1
    Last Post: 04-29-2008, 12:52 AM
  2. On-Board Digital Equalizer
    By Cheekz185 in forum Car Audio
    Last Post: 05-24-2005, 06:47 PM
  3. Frustrated with my digital WW board....
    By Waveblaster785 in forum LCD/Display
    Last Post: 03-12-2005, 05:42 PM
  4. Fried my Digital WW board....
    Last Post: 02-21-2005, 10:26 PM
  5. SB Value Digital I/O Board???
    By RaZor in forum General Hardware Discussion
    Last Post: 04-19-2001, 12:45 AM
