Page 24 of 31 FirstFirst ... 141516171819202122232425262728293031 LastLast
Results 231 to 240 of 303
Thread: DAB DAB+ FM Digital Radio Development Board
  1. #231
    Feb 2012
    UK
    Personally I haven't been able to get the new board to produce raw RDS data either. Haven't had a chance to check with JP about it yet.
    Sent from my Nexus 4 using Tapatalk 2
  2. #232
    Maximum Bitrate Mickz's Avatar
    Sep 2009
    Australia
    Quote Originally Posted by swissdealer View Post
    Hi Mickz,
    congrats on your app, really looks and works great. I'm working on a customized version with your demo as the source, which by the way makes it quite easy to get an understanding of how it works.
    I'm wondering if the new Pro Board has improved RDS capabilities, with the "old" board I can't get any info out. Since you seem to have the new one for quite a while, could you let me know your observings?
    Hi and thanks swissdealer. I assume that you're referring to Demo SW supplied by JP from Monkeyboard. I haven't posted source code for my latest APP as yet. I also haven't bothered to get DLL source code as I'm happy with the supplied DLL so Dabbler would be the one to listen to here as this is what he's playing with.
    GA-Z77N-WIFI, i5-2400S, 8GB, Intel 520 128GB SSD, M4-ATX Modified, 2 Rev Cams, 2 Web Cams
    8" 16:9 TRANSFLECTIVE, Win8-64, Dual GPS RX and Garmin PC + Odyssey Nav, FM-DAB+, BB-Rec
    T-Screen HVAC control, custom microcontrollers, code and FE. CarPC Project
  3. #233
    May 2012
    Grandville, MI
    I have been trying to stay up on this thread... I am guessing there is no way to support HD Radio for the US with this board.
    Might be interesting to play with just to get FM/AM here in the US but would be nice to be able to get HD since I have numerous stations around me.
  4. #234
    ibf
    ibf is online now
    Oct 2010
    Hi Mickz,
    I dont have the old board but I do know that the RDS on the new board partly work, I have seen the PS and PTY work, I havent seen RT work at all. The strange thing is there is a station here at 87.60Mhz with very strong signal and RDS capable radio would decode it within second while the monkeyboard couldnt decode at all.
    EDIT:
    Just seen radio text working on 105.8MHz (Absolute Radio) so all is good. Im still not sure why 87.60Mhz doesnt get decoded though.
  5. #235
    ibf
    ibf is online now
    Oct 2010
    Im getting bad audio interference at around 100MHz on the FM, a tone repeating itself at around 5Hz which seems to coincide with the RX/TX activity and moving the audio cable about lessens it, is anyone else getting this?
    Have anyone successfully controlled the module directly without going through the dll?
  6. #236
    Sep 2009
    Australia
    Quote Originally Posted by ibf View Post
    I find USB cable ground and MB audio out ground impedances tend to highlight USB data signalling interference. A good ground from the module to the PC helps remove it, also it's more noticeable on one PC but not on the other.
  7. #237
    Sep 2009
    Australia
    I have Program Identification, Program Type and Radio Text on some FM stations but as I don't use FM I haven't really compared this to another Radio for stations that have none, will do when I get a chance.
  8. #238
    Sep 2009
    Australia
    Quote Originally Posted by redheadedrod View Post
    Correct, no HD so FM is all you're left with unfortunately.
  9. #239
    Feb 2012
    UK
    When running on FM you will be much more prone to interference from any nearby/connected equipment. Mitchz tips are good for this.
    I'm still only using the supplied antenna at the moment which works OK for dab, but not so much for FM. This probably explains my patchy RDS, as that needs a decent signal.
    I have been controlling the module from my own code directly yes. According to the documentation it should be possible to get raw RDS data from the module. But my initial tests didn't produce any.
    I'm away visiting for Christmas at moment, when I get back I'll try again with a better antenna.
  10. #240
    Sep 2009
    Australia
    For anyone trying my APP, I found a glitch with Volume on resume from hybrid-sleep where sleep fails for any reason. The Module sound was occasionally staying muted -fixed and uploaded.
  1. Replies: 1
    Last Post: 04-28-2008, 11:52 PM
  2. On-Board Digital Equalizer
    By Cheekz185 in forum Car Audio
    Last Post: 05-24-2005, 05:47 PM
  3. Frustrated with my digital WW board....
    By Waveblaster785 in forum LCD/Display
    Last Post: 03-12-2005, 04:42 PM
  4. Fried my Digital WW board....
    Last Post: 02-21-2005, 09:26 PM
  5. SB Value Digital I/O Board???
    By RaZor in forum General Hardware Discussion
    Last Post: 04-18-2001, 11:45 PM
