Results 11 to 20 of 21
Like Tree1Likes
Thread: LED Headlight Module
  1. #11
    Maximum Bitrate tempgp's Avatar
    Jun 2007
    New York
    Quote Originally Posted by JasonLuvin View Post
    That design looks awesome man good job. Any chance we can get an approx when we can see the final touches?
    Final product delivery depends on community interest in it
    I just happened to be out of budget so to do the project I need to release few of our commercial jobs to raise some money for toys like this. Otherwise the designs are ready to be send to production houses. I might to do some more improvements in the meanwhile
    Acura / Honda A/V CarPC Adapter GA-NET+
    Centrafuse Garmin Mobile PC Skin - GMPC Rebellium Skin
    3D Tuning and Car Visualizer - Preview your car in 3D, change paint job and rims
  2. #12
    North of the land of Hey Huns
    Jun 2004
    Westminster, MD
    Quote Originally Posted by tempgp View Post
    as to price this is some what tricky. So far production will be really manual small quantity batches for people i know so price will be high. Id say very high, but yet cheaper then stock HID kits (ex Mercedes stock HID lamps are 800 each)
    So this is more aimed at the upper end car market? I know a HID conversion kit for my car (Mazda protege) is only $200, I assume you're not aiming to compete with that?
    RevFE
    My Shop
  3. #13
    Jun 2007
    New York
    Quote Originally Posted by malcom2073 View Post
    yes this will be an expansive installation. Goal is not just hit "upper" market but rather deliver modular innocation so we can do something differently from what ever come as stock option.
    My end goal is to build complex motorized system where I can Pan, Tilt, Zoom lesnses so we can adjust settings to different road condition. Also maybe add RGB leds so we can select color that is best for curent situation ex Blue during sun light and Cool White at night etc . but all that is on ToDo list
  4. #14
    Jun 2007
    New York
    Hey all we have progress in our development, prototype is made so next week we will ger metal version done and test operability
    Name:  tempgp_solidstate_led_headlight_prototype (Medium).JPG
  5. #15
    Constant Bitrate ephect's Avatar
    Jul 2007
    Melbourne, Australia
    looking good,
    can you throw up some more details on the LED ur using?
  6. #16
    Jun 2007
    New York
    led can have different configuration. easiest one to integrate is 12V 800 Lumins @ 1.3A
    with current footprint we can go up to 2200LM but power adapter would be need as led requires 16.6v @ 2A
  7. #17
    Jan 2008
    not too hard to find..
    you just need one of these:
    http://www.current-logic.com/shop/in...products_id=38
  8. #18
    Jun 2007
    New York
    yes we can use power adapters like that. They are OK as alternative but better to get something more reliable. That Chinese design has issue with voltage stability. Ex we had 16V regulated output but under 2A load voltage drops to 14V which results in lower light output and thtas not fun. We think problem in capacitors that they are using.
  9. #19
    Jun 2007
    New York
    havent been here for a while we have manufactured updated heat sink which is lighter and more better in terms of temperature disbursement. It is compatible with all Bridgelux ES high power LED arrays. Tested with 880 /1500lm bulb with fan runs frozen and if fan stop led runs withing allowed temperature range!
    We still working of reflector part to make it perfect but so far this works quite well!
    If any one needs our coolers let me know we got few available!
  10. #20
    May 2012
    Grandville, MI
    I do hope you won't have that PC style fan on a production model since those are not weather proof and will die quickly.
    You may want to use a different style of heat sink if they create that much heat. Or maybe even consider a thicker heat sink of similar design with a water cooler setup for them. I would trust putting a water cooling radiator in front of my regular radiator and a water pump pumping antifreeze through both headlights and the radiator before trusting something like this...
  1. Stopping Headlight Flickering
    By PaulF in forum Power Supplies
    Last Post: 11-21-2009, 11:51 AM
  2. headlight wiring?
    By ZX2fst in forum General MP3Car Discussion
    Last Post: 08-05-2007, 08:36 PM
  3. Headlight LCD mod
    By bellerophon in forum Fabrication
    Last Post: 11-02-2005, 04:13 AM
  4. Headlight LCDs
    By rsd212 in forum LCD/Display
    Last Post: 08-19-2005, 02:01 PM
  5. Headlight question...
    By ODYSSEY in forum Off Topic
    Last Post: 03-17-2004, 03:30 PM
