Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Like Tree1Likes
Thread: LED Headlight Module
    Maximum Bitrate tempgp's Avatar
    Jun 2007
    Hey all, just finished designing our LED headlight module for LED matrix of 800-2500 LM. Just wanted to share the progress
    Lens is 40mm, fan base is 50x50mm, this is small enough to fit in may places yet provide as much light as HID kits
    Tell me what you think?
    DigitalVampire likes this.
    Automotive LED Headlight Module High Power VS HID NEW
    Acura / Honda A/V CarPC Adapter GA-NET+ - Convert your native navi DVD unit to CarPC + Dash buttons are usable in car pc!!!
    Centrafuse Garmin Mobile PC Skin - GMPC Rebellium Skin
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    very interested in this. any images of the product in use?
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
    Mar 2012
    New Jersey
    Would the light temperature and power input requirement be equivalent to an HID kit? Also, do you imagine it competing at a similar or lesser cost than the average competing HID kit?
    "It's not worth having if you can't customize it"
    Jun 2007
    i have hand made prototype installed in my car but due to heat-sink being generic i was only able to go up to 800LM which is ok for NYC but kinda dark for not lighted roads. I am currently machining parts for this design so if all goes well i will have production parts ready next week and i will do some testings on the road with various LED matrices. My main interest is 2000LM for this design and 5000LM for next bigger version ( considering that average HID is 1500LM,l my design should look nice
    Jun 2007
    Quote Originally Posted by duncanator24 View Post
    Light temperature on matrix we have is cool white which is the same as most factory HIDs (we don't have blue versions that are very common to aftermarket HID kits) as to price this is some what tricky. So far production will be really manual small quantity batches for people i know so price will be high. Id say very high, but yet cheaper then stock HID kits (ex Mercedes stock HID lamps are 800 each)
    As to power output as i mentioned in other post average HID is 1500 LM, our small 40mm lens kit can handle up to 2000LM which is more then HID and it eats twice less power, so in my case i will use that as fog light when i need extra coverage on dark roads. And for extremes 60-90mm kit can handle up to 12,000 LM which is aircraft projector and HID would look like candle light next to it. I think 5000 LM is max what you might ever need on the road
    Jan 2008
    looks like your putting the led vertical to face the lens, why not place the led horizontal to better control the distribution of light? also, what led's are you looking at that only come in cool white?
    My 2001 Mitsubishi Eclipse GT:
    "The Project That Never Ends"
    more projects then time!
    Led Skyline Tail Lights--100%
    High Power Led Reverse Lights--100%
    Led third brake light--100%
    Led front turn signals--0%
    HID retro--100%
    Jun 2007
    what do u mean vertical horizontal? our matrix is square no meter how u put is its still square
    we are using bridge lux matrix, they come in cool or warm white
    Also progress update, i cut heat sing out on our CNC, progress was not good as router did not hold height well so i will need to do another run tomorrow
    Jan 2008
    Quote Originally Posted by tempgp View Post
    i mean the orientation when looking at it from the side-- this is how the OEM's do it:
    http://www.hidplanet.com/forums/show...l=1#post491038
    i fear that by just placing a COB array behind a projection lens, you will be creating a high beam light-- which is not very usable for most cases. the only way for it to work for low beam use is to block off portions of the COB array, which would of course drastically affect its lumen output.
    HID retro--100%
    Jun 2007
    that's a cut off filter, we can position it any way you want, in our design it is right between reflector and lens so minimal radiation is lost. At the end of the day assembly can be used as both high beam and low beam. Also im waiting for laser cutter to arrive, when i have it i would be able to shape the lens surface so we can have less light for high beam, so it would be like high beam that does not blind incoming drivers that much.
    Aug 2012
    That design looks awesome man good job. Any chance we can get an approx when we can see the final touches?
  1. Stopping Headlight Flickering
    By PaulF in forum Power Supplies
    Last Post: 11-21-2009, 10:51 AM
  2. headlight wiring?
    By ZX2fst in forum General MP3Car Discussion
    Last Post: 08-05-2007, 07:36 PM
  3. Headlight LCD mod
    By bellerophon in forum Fabrication
    Last Post: 11-02-2005, 03:13 AM
  4. Headlight LCDs
    By rsd212 in forum LCD/Display
    Last Post: 08-19-2005, 01:01 PM
  5. Headlight question...
    By ODYSSEY in forum Off Topic
    Last Post: 03-17-2004, 02:30 PM
