Page 4 of 4 FirstFirst 1234
Results 31 to 35 of 35
Like Tree1Likes
Thread: arduino to read car sensors
  1. #31
    May 2010
    Herákleion, Iraklion, Greece, Greece
    no problem of course dude my audi was from 1992, but i think that many other models of audi 80, with enother engines (1.8lt ++ ) indeed had diagnostics!!
  2. #32
    Raw Wave
    Nov 2009
    Reading the codes could be a solution...
    I didn't answer Settra's earlier issue with reading resistances - ie, "... the resistive sensors are a problem for many reasons. mainly because, since their resistance changes, you cant use a diode to isolate the grounds...". Hence the desire for the common grounding of sensors and the avoidance of non-linear insertions - eg. diodes.
    But the sensor's voltage can be compared to a map or maybe calculated to derive an appropriate output eg, 0.6V = 0; max 7V via 18/25 voltage divider as about 3.0V = 100%; 3.9V => 55%, etc. That's the beauty of using uPCs like Arduinos, PICs, etc - the input signal mapping is programmable.
    As long as the measuring doesn't effect the line's voltage or current (ie, as high Ohmage/impedance as possible) things should be fine. (If not, use a voltage follower or buffer.)
    Isolating thru diodes should generally not be necessary.
  3. #33
    Variable Bitrate AutoWiz's Avatar
    Jun 2013
    Pompano Beach, FL
    hi settra. I believe I can help you. I have access to all the information you need for your project through shop databases, and my awesome snap-on vantage pro. most automotive sensors run on 5v and will work beautifully with arduino. but, if you tell me year, make, model, engine, and what sensors you need what info on, I will post here for you. shop manuals will tell you how to take the car apart, and if your lucky maybe have some wiring diagrams or a list of trouble trees for codes thrown, but usually they do not include sensor calibrations. in fact, even shop databases like Mitchell or shopkey and alldata don't have sensor calibrations past what is needed for testing and diagnostics. the 2 channel lab scope I bought from snap-on and have updated twice a year has really proven to be indespensible in this area. it holds and stores pinouts for ecu's, pinouts for every sensor connector, description and operation of every sensor, a ruff calibration (but good enough to setup a tune with), and even an example waveform of what that sensor's signal should look like. for every car. that's why the updates. let me know what ya need.
  4. #34
    May 2010
    autowiz, thanks for the help, but if you look in the previous posts, we have been over this...
    i have actually completed this project months ago (Actually now, i am upgrading even further), so no need for help for the record, 5v are sensors, of newer cars , that have logic ECU modules and stuff. in older cars, (mine etc) , the sensors where 12v UNREGULATED
  5. #35
    Jun 2013
    Pompano Beach, FL
    yup, just read the first page and skipped to the end. my bad.
  1. OBDII Arduino Shield
    By bwallen in forum Hardware Development
    Last Post: 01-19-2015, 10:07 PM
  2. Developing an arduino shield - any interest?
    By CyberBill in forum Open Source Hardware
    Last Post: 02-20-2013, 10:39 PM
  3. Arduino as a touchscreen controller. Is it possible?
    By HiJackZX1 in forum General Hardware Discussion
    Last Post: 11-23-2012, 02:20 AM
  4. Arduino for OM - In progress
    By jmullan99 in forum OpenMobile
    Last Post: 03-13-2011, 05:43 PM
  5. Using Arduino to Auto-dim LED EBY701?
    By stevey500 in forum LCD/Display
    Last Post: 08-21-2010, 01:04 AM
