Results 1 to 1 of 1
Thread: 12v CD player volume control with rotary encoder and push buttons? Please HELP!
    Feb 2009
    Hello all. I am trying to get the final stages of a media center figured out. My setup integrates a hidden pioneer deh-p6400 cd player (just for eq and volume control) and my tablet. Where I am getting stuck is with the volume control. It uses a rotary encoder and I would like to integrate push button controls for volume up and down too. The push button control unit has 3 wires, one for volume up, volume down and a wire to connect power or ground through the switch. Is there a way I can use some logic chip to output the same binary signal needed when I press a push button either way? I uploaded the schematic for the cd player volume control circuit.
    I have tried connecting a wire from the gnd terminal and touching it to either of the lines that have the 5v. It does not change it that way.
    I also checked the encoder and it was pretty random for the frequency. I couldn't see a pattern. I think it was relative to the speed I spun the knob. So I made a 555 timer astable mode circuit and outputed to 65Hz. I ran it off the cd players power and tried outputting the 5v 65Hz to the signal wires and it didn't change the volume. I didnt think the input voltage should be from the wire SWDVDD (pin11) do you? Do you think the output for volume down should be to Pin11 and volume up be RDTO (pin4)? Or is the power for the encoder pin 11 and depending on the binary out from the encoder to pin 4 changes the volume? Any advice would help!
  1. Replies: 0
    Last Post: 08-21-2014, 10:27 PM
  2. New Phidgets Encoder volume control util
    By meisner in forum Input Devices
    Last Post: 02-17-2010, 05:14 PM
  3. Rotary & Slide Volume Control
    By SKiTLz in forum Fusion Brain
    Last Post: 12-18-2007, 01:07 AM
  4. I need help with those rotary encoder thingies
    By tominated in forum Input Devices
    Last Post: 11-27-2006, 02:05 PM
  5. Phidget Encoder and RR Volume Control
    By BLOWNZO6_pc in forum Road Runner
    Last Post: 10-25-2005, 11:00 AM
