Page 4 of 6 FirstFirst 123456 LastLast
Results 31 to 40 of 56
Thread: Schematics/Pin Outs/Diagrams
  1. #31
    Oct 2005
    Hi guys try this website out, has lots and lots of connectors.
    Let me know what you guys think.
    http://pinouts.ru/cgi-bin/list_conn.cgi
    Cheers
    Guruj
  2. #32
    Maximum Bitrate JimmyFitz's Avatar
    Nov 2005
    Austin, Texas
    Shutdown Controller "Keep ON" with auto Reset
    This circuit will bypass the ignition switch signal in order to keep an M1-ATX on after the key is turned off. The push button and LED are mounted on the dash. To keep the PC on during a quick stop, I push the button before turning off the key. The LED lights up to indicate the Latched on state. The system will automatically reset to normal (unlatched) the next time the key is turned on. The circuit will also unlatch if the PC turns off for any reason (low battery, software shutdown, PC power switch, etc.) This circuit has been tested with M1-ATX, but should work for other SDC's with ignition control signal.
    ~Jimmy
  3. #33
    Jan 2006
    Since the Mute line in a car may be already used, adding a Handsfree Kit or other device with a Mute line needed some "glue" logic.
    Common Car Mute line function is active low, a 74HCT08 2-Input AND Gate is used so any low input will cause a low output to the radio. A 7805 5V regulator is used to power the logic gate. Pull up resistors are added to keep the input/output stable preventing any unwanted mute condition caused by drifting line levels. If more than 1 Mute line needs to be added, a 74HCT11 3-Input AND Gate can be used instead.
  4. #34
    Feb 2006
    I'm looking for the pinout of a 2003 ford cd-6(indash 6-disc changer) 20 pin cd changer.I'm trying to get aux input out of it!Ive looked and looked and If anyone could help me it would be appreciated!
  5. #35
    Constant Bitrate i3igmind's Avatar
    Mar 2005
    Regarding the carPC Turn On / Shutdown Controller i ve one questions?
    1) What if i don't have COM port ? can i use USB or Parallel port?
    HOnda Accord '94
  6. #36
    Low Bitrate jospfh's Avatar
    Jan 2003
    Netherlands
    Simple car battery tester
    Link: Simple car battery tester
    Free circuit designs at www.circuitdb.com!
  7. #37
    Newbie antonio_riq's Avatar
    Nov 2005
    Madrid, Spain
    For anyone looking for any kind of connection description forward this link. Is the most complete and easy to understand Connector description (graphic & text) I have found.
    http://www.hardwarebook.net/connector/
    IN ENGLISH
  8. #38
    Raw Wave tj!2k4's Avatar
    Oct 2004
    Oct 2004
    PS2 Port Pinouts
  10. #40
    Nov 2005
    Madrid, Spain
    Sorry, I've wrote the wrong link. The right link in English is:
    I've allready corrected in my message.
    Hope this link helps anyone seeking for any kind of connectors!!
