Page 1 of 6 123456 LastLast
Results 1 to 10 of 56
Thread: Schematics/Pin Outs/Diagrams
    Jan 2003
    Ruston, LA
    This thread is for schematics, pin-outs, and diagrams ONLY.
    NO COMMENTS. IF YOU WANT TO MAKE A COMMENT OR ASK
    QUESTIONS, MAKE A THREAD IN THE APPROPRIATE FORUM.
    FORMAT RESTRICTION:
    Schematic Purpose:
    Pictures/Notes:
    Extra Notes:
    Have fun guys
    Frodo
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
    Hayling Island, UK
    S-Video Pin out
    Pin Name Description
    1 GND Ground (Y)
    2 GND Ground (C)
    3 Y Intensity (Luminance)
    4 C Color (Chrominance)
    Code:
    3  o o  4
    1 o   o 2
    4 pin Male
    ill try get an image instead, but for now it will do
    MySQL Error jcdillin's Avatar
    May 2003
    Miami, FL
    Garmin GPS 4 Pin Connector
    Pin connector as seen from back of unit
    Pin Name cable color
    1 power input red
    2 ground black
    3 data out brown
    4 data in white
    FLAC Chairboy's Avatar
    Jan 2004
    gah, no sense of humor.
    Quick method for regulating 12+ to 12v steady. There's a voltage drop off of around 1v or so. Using a 7505 or 7509, you can get regulated 5v or 9v too respectively.
    Note: Less then 1 amp load. You cannot get regulated 3amps by just using 3 7512s or the like, so don't try.
    Jan 2004
    Serial pinout:
    Constant Bitrate Zoltan's Avatar
    Jun 2004
    Warrensburg, MO
    Auto Power-Up laptop
    Sends a momentary pulse to push the power button when the computer senses the charging go from cold to hot AND it's not already awake.
    Enjoy!
    '03 Escape 4WD:
    -iTox mini-itx mobo, Core 2 Duo Mobile 1.66Ghz; 2GB, 80GB 2.5" HD, DS-ATX
    -Transflective 8.4"
    -XM, iG4, OBD-II (BR-3)
    -Rearview camera with auto-switching (modified cheesbox)
    -Slim Slot DVD+RW
    -RR, DFX 4
    Nov 2003
    Marietta, GA
    "Valet" switch to bypas ITPS/Opus/CarNetix
    Here is a switch configuration that let's you manually control your PSU. It works for ITPS, Opus, and CarNetix type PSUs.
    MikeH
    Variable Bitrate stimps's Avatar
    Nov 2001
    brisbane
    Heres the pinout for your normal DB25 printer cable to use for wiring up HD44780 type LCD's
    Nov 2001
    brisbane
    relay circiuts.
    These circiuts you may find usefull to "trick" a motherboard into powering up just after it has recieved batt power thru an ignition relay and a "on pulse" is needed to fire up the atx motherboard connection. There are plenty of other uses for them if you can think of them. Such as dethump power dissconection of amps during head unit turn on, etc.
    Constant Bitrate Gibson99's Avatar
    Aug 2004
    Houston, TX, USA
    just found this site which lists a ton of connectors and all their relevant pinouts.
    http://www.networktechinc.com/technote.html
    has common pc, mac, sun, sgi, paralell, serial, usb, 1394, video, and other connectors i've never even seen before.
    Previous: CamryAmp 1.0 - 95 Camry SE V6 Coupe (sold)
    Current: CamryAmp 2.0 - 98 Camry CE V6 5spd (still bench-testing)
