Page 10 of 55 FirstFirst 1234567891011121314151617181920 ... LastLast
Results 91 to 100 of 541
Thread: Anyone interested in serial controlled Relay/Input card?
  1. #91
    Raw Wave
    Jun 2003
    Quote Originally Posted by BeaverWise
    For something that might spark some ideas on the software side of the house take a peek at http://www.controlanything.com/manuals/IOADR8x.PDF
    I am still debating what to do... I really like the capabilities of the card made by NCD, but if it can't be used in an automotive environment...
    Ideas anyone?
    You can still use that card as long as you prepare the car +12V before you feed it into the cards input. Maybe you also need a voltage regulator for the card power supply.
    How much is it?
  2. #92
    Maximum Bitrate kiltjim's Avatar
    Feb 2004
    PA, USA
    I know some about electronics, more then enough to keep me in trouble... but...
    Is this board going to be capable of digital outputs? Other than driving relays?
    What I was hoping to do is pulse a channel very rapidly at variable frequencies. This would be to drive a transistor to rapidly switch (PWM) cold cathode tubes, and maybe underglow. Is this going to be possible? Like instead of hooking up one of the outputs to relay hook it up to a transistor? Is this going to be too much for the board?
    2000 Subaru OBS
    Dell P3 @ 900 Mhz
    7" Lilliput TS w/DigitalWW in-dash mount
    80GB External HD
    I am Zero Bitrate....
  3. #93
    Variable Bitrate HybridFox's Avatar
    Oct 2004
    Peterborough/Ontario/Canada
    (just wanted you to know before you read my post that when it comes to serial ports and relays i am COMPLETE NEWB)
    -what the hell is the difference bettween analog and digital inputs?
    -what program do you use to incorporate button pushes into switching relays? (how is it that you can make a window with buttons so that when one of them is clicked/pushed it will send a signal through your serial port into this board thing and open/close a relay?)
  4. #94
    lez
    lez is offline
    FLAC lez's Avatar
    Jan 2004
    UK
    Quote Originally Posted by kiltjim
    I dont think your tubes will like you very much......
  5. #95
    lez
    lez is offline
    FLAC lez's Avatar
    Jan 2004
    UK
    Quote Originally Posted by Ricky327
    (1) Wow I never though of that one. I think its best to use those REED relay for this.
    (2)Bear in mind that the board is capable of having upto 5 ADC...modifying the firmware will give you this. But of course you will lose some digital inputs.
    1) reed? na just simple 4pole thing from maplins, but yes, car relays unreliable bits of meccano....
    2) didnt know chip was that capeable, last pic i touched was f84 and that hit the window....
    would be nice to write a screen saver that read analog imputs from the card and displayed oil/water/speed/rpm etc when mediacar/mediaengine was not in use....
  6. #96
    Feb 2004
    PA, USA
    Quote Originally Posted by lez
    I was worried about this, but sound activated controllers do this, don't they?
    I wasn't going to vary the voltage, just vary the amount of time they were on.
    Quote Originally Posted by HybridFox
    Analog inputs would be a varying voltage. Its neither on or off. Like your car voltage. Digital inputs would be like your car is either on or off. Either you have voltage or you don't. Digital usually hovers around either 3 or 5 volts, but in your car, it is at 12 volts (roughly).
    I'm working on something that will send some commands using VB.NET. Some simple buttons and all they do is send a command. Once this card comes out though, I'm going to have to change all the commands, but all you really need is a nice little .DLL thats allows you to access the serial port, or a USB port, or whatever.
    2000 Subaru OBS
    Dell P3 @ 900 Mhz
    80GB External HD
  7. #97
    Constant Bitrate BeaverWise's Avatar
    Oct 2004
    Germany
    How much is it?
    The version mentioned in the post above is $329. The thing that I really liked about this card was the expansion capabilities and the variety of add-ons. Here is a link to more of their stuff. Look it over and give me your impression if you could.
    http://www.controlanything.com/Merch...ry_Code=HYBRID
    PS - I have absolutly nothing to do with this company, just looking for a good solution for my car..
  8. #98
    Raw Wave
    Jun 2003
    $569 for a relay card...thats alot.
    Well all of them seems like a good board but the price is just too much.
    To make a card with this much feature :
    16 x Relays
    16 x Digital inputs
    8 x Analog inputs
    Im sure it wont cost no more than $70
    I dont think the LCD interface is really that necessary for car PC use.
  9. #99
    lez
    lez is offline
    FLAC lez's Avatar
    Jan 2004
    UK
    well I was wanting to make a phone controlled car alarm, as then I dont need to carry keys+phone+keyfob etc, plan was to just carry phone, have it control the alarm, and wire out the keyswitch.
    thats what I was going to sling some relays off the lpt port for, but will be using this card instead as I prefer serial control as thge lpt port can be accessed by other windows progs which may cause errors, ie car starting at 4am.......
    I have software in testing (sms) stage at moment, looks ugly but works, I can unlock/lock doors etc with a text meassage, now want to build in blutooth so I can unlock car from a menu option on my phone.
    I know its possible(from looking at pc control), just not figured it out yet.
  10. #100
    Jan 2004
    Having just read the entirety of this thread I am very excited!
    I was contemplating designing a similar circuit, that controls a relay that connects/disconnects a tank battery to the alternator depending on the voltages of the two batteries. eg if the tank goes below 13.3V (min input on itps) and the car is running and the voltage of the main battery is above 14V then alternator is connected to tank which then charges.
    Was contemplating putting a digi sensor on my auto-box selectro so that if in manual or park the alternator is disconnected.
    Vaguely remember reading in the thread that the max current for a relay was limited, is this the case? If so would controlling a 100amp relau with a reed relay be feasable?
    Cheers
    ps GREAT WORK
  1. Ewww sound card + video card on dual pci mini-itx reiser card = audio interference
    By psyclobe in forum Software & Software Development
    Last Post: 01-23-2008, 02:59 AM
  2. anybody tv/fm card troubles
    By marsjell in forum Software & Software Development
    Last Post: 09-01-2005, 08:08 AM
  3. Via Mini-ITX Epia 5000 serial port not working
    By vash in forum General Hardware Discussion
    Last Post: 08-13-2002, 09:48 PM
  4. help - video card problems
    By Cliff in forum General Hardware Discussion
    Last Post: 04-15-2002, 06:25 PM
  5. 2 db-9 serial ports PCI and credit card remote
    By moahdib in forum Classified Archive
    Last Post: 07-25-2001, 12:41 AM
