Page 38 of 43 FirstFirst ... 28293031323334353637383940414243 LastLast
Results 371 to 380 of 429
Thread: HU Quality AM/FM RDS/RBDS Radio with Features
  1. #371
    Aug 2004
    Hey,
    The first look on the almost finished PCB design.
    btw the gnd areas aren't drawn yet for the criticy just to be clear
    Regards,
    Rogier
    Professionals built the Titanic, an amateur built the Ark.
  2. #372
    Maximum Bitrate Marsupial's Avatar
    Feb 2004
    Montreal
    schweeeeete.
    how's the antenna going to be attach? (I know close to nothing about antennas, sorry)
    Also, the chips, won't those be hard to solder for a DIY kit?
    -Mars
  3. #373
    Constant Bitrate Ill1's Avatar
    Jun 2004
    Woodbridge, VA
    Chips aren't hard to solder in as long as you don't solder the chip directly to the board. That usually causes the chip to burn up. You would solder a chip holder (don't know the exact name) to the board and then insert the chip in the correct orientation.
    ________________
    ______ILL.1______
  4. #374
    Registered User mpattonm's Avatar
    May 2003
    Czech rep.
    Quote Originally Posted by Ill1
    ... a chip holder (don't know the exact name) ....
    Its called "socket", just to be precize.
  5. #375
    Jan 2005
    It would be difficult (impossible?) to find a small, inexpensive socket for a surface mount IC to fit on that board (without interfering with nearby parts). It really isn't too difficult to solder the IC to the board, just have to an iron that won't cook everything. One method that is often used for smaller pitch IC's is to solder one whole side together (lined up correctly), regardless of shorts. Then just use solder wick to remove the excess solder. Believe it or not, IC's come in much denser packages than even those on this board (from what the layout looks like, at least).
  6. #376
    Maximum Bitrate Seth's Avatar
    Jun 2004
    Athens Greece
    There are no sockets for those SMD chips. THT variants of those chips have some disadvantages :
    1) They are huge
    2) THT technology intoduces self-capacitance in the soldering points and parasitic resistance due to the size of the pins in RF circuits.
    The key is to use a low wattage soldering iron (~30W), a magnifier lamp and lot's of patience.....and don't drink coffee...
  7. #377
    Aug 2004
    Germany
    hm will there be a completely assembled board or a ready for sale product? because i dont trust my soldering skills
    Golf 3 CarPc Status
    ///////////////50%--------------/
    PSU:Inverter
    GPS:BT GPS
    PC: Slim notebook with 10.4"touch, external DVD.
    Dock for car is in production.
    Audio: Stock speakers but looking for new ones. CD-HU with FM modulator (ordered)
  8. #378
    Aug 2004
    The antenna will be the normal socket used on car radios and will be connected by a short shield wire.
    The IC used here are fairly easy to solder if you keep a few points in mind. First like Seth said is a low power solder iron with a fine tip. Fine solder wire 0.7mm max.
    Normally the PCB has a tin layer on the pads and wires, so you put the IC on it line it up precisely and solder pin 1 and the last pin = the one opposite diagonal. then you solder the rest. best to solder a few pins and let the IC rest for a while to cool down. SMT is more sensitive for heat then normal components. Sometimes a second pair of hands can be useful.
    If everythings goes well i will try to make a prototype this weekend and post some pictures of it.
  9. #379
    Raw Wave rando's Avatar
    Mar 2004
    Redondo Beach, CA
    A prototype? YES!!!!!!
  10. #380
    Jun 2004
    The North, Manchester
    you have made one????
  1. 1/2 din AM/FM radio ????
    By spectrrr in forum General Hardware Discussion
    Last Post: 10-08-2005, 08:45 AM
  2. AM/FM USB radio, and more: RadioShark
    By Chairboy in forum General Hardware Discussion
    Last Post: 04-06-2004, 06:14 PM
  3. AM/FM Radio Chip
    By orangewhip in forum General Hardware Discussion
    Last Post: 03-25-2004, 08:31 PM
  4. Custom AM/FM radio display?
    By ShinkunoNamida in forum General Hardware Discussion
    Last Post: 02-25-2003, 08:28 PM
  5. AM/FM radio
    Last Post: 05-15-2002, 09:40 PM
