Page 10 of 23 FirstFirst 1234567891011121314151617181920 ... LastLast
Results 91 to 100 of 222
Thread: XMDirect Cable
  1. #91
    Maximum Bitrate R32 JUhl's Avatar
    Nov 2004
    North Atlanta
    Quote Originally Posted by Grayscale
    Man, are you kidding me? They are 166MHz Pentiums! How much RAM do they have in them? And what kind of RAM is it? I was thinking more along the lines of $50...!
    I don't know what they're worth! I saw one sold on Ebay for $99 via Buy It Now and figured that it was fair. Let me get the covers off and see what kind of RAM we're dealing with. They're 200 MHZ Pentiums, I'm pretty sure. I'll get back to you.
    Man, I would keep playing with that cable if I was you! As long as you don't get the power reversed, you can't really screw it up!
    I'm tapped out of ideas, though. I must have done something wrong, but I don't know what - or my XMD is bad (not likely). I get the same results from two different computers and I'm 100% positive that I was able to get the XM antenna in a good enough place to catch a signal - right next to my other fully functioning XM antenna... Besides... the money's spent on the new cable.
    My first attempt at a carputer.
    PM me if you're interested in a monitor faceplate for your '99-'04 Golf or Jetta. My Vortex ID is NorthAtlR32 - you can IM me there, too. Go here for more information.
  2. #92
    MySQL Error jcdillin's Avatar
    May 2003
    Miami, FL
    so your having a problem with the new cable or the cable you built?
    肚子笑痛了
    S60 Install
  3. #93
    Nov 2004
    North Atlanta
    Quote Originally Posted by jcdillin
    it's pretty much as simple as that.
    I added a 220uf polarized cap on the output of mine just to keep noise out of the line but for the XMD you should not need it.
    and these are the units I am using
    http://www.fairchildsemi.com/pf/KA/KA7812.html
    As usual, thanks for your help!
  4. #94
    Nov 2004
    North Atlanta
    The one I built. Probably won't see the new one before the middle of next week. S'okay I guess. That will give me plenty of time to work on my acrylic housing.
  5. #95
    May 2003
    Miami, FL
    did you try swapping the serial tx and rx pins just to make sure that it wasnt crossed serial lines?
    肚子笑痛了
    S60 Install
  6. #96
    Nov 2004
    North Atlanta
    This looks line ONE of them. http://cgi.ebay.com/ws/eBayISAPI.dll...tem=5724329424 The other two have LCD displays. I'll get you the details after Enterprise is over.
    I'm in Atlanta. Have you considered how much shipping will be for these monsters?
  7. #97
    May 2003
    Miami, FL
    Quote Originally Posted by R32 JUhl
    No problem, let me know if you need any other help with that.
    肚子笑痛了
    S60 Install
  8. #98
    Nov 2004
    North Atlanta
    Oh, you can bet on it!
    So the center terminal is actually number three/ground, huh?
  9. #99
    Nov 2004
    North Atlanta
    Um... no... What the hell - I've give it a whirl! But I did doublecheck my wiring with a Fluke and the pins match identically to your first post with continuity from xm pin 1 to ser pin 3, xm 2 to ser 2 and xm 3 to ser 5. I'd be willing to swap the two to see if something is screwy...
  10. #100
    May 2003
    Miami, FL
    yes, center is ground.
    Yeah I would double check it on the serial connector because I always seem to get them backwards. there should be tiny numbers next to the pins.
    肚子笑痛了
    S60 Install
  1. Earthmate USB to Serial cable
    By New_Compact in forum GPS
    Last Post: 05-22-2008, 02:55 AM
  2. XMDirect Digital Audio Project ?
    By Retsaoc in forum General Hardware Discussion
    Last Post: 10-11-2004, 10:26 PM
  3. where should i go to get a cable?
    By blackpacu in forum LCD/Display
    Last Post: 09-08-2004, 01:25 AM
  4. A cable I found.
    By masterful in forum LCD/Display
    Last Post: 08-17-2003, 10:36 PM
