Page 15 of 23 FirstFirst ... 567891011121314151617181920212223 LastLast
Results 141 to 150 of 222
Thread: XMDirect Cable
  1. #141
    Low Bitrate Imagex's Avatar
    Jun 2004
    Quote Originally Posted by R32 JUhl
    I'm beginning to wonder if something changed in the XMD1000...
    They would have to change many headunits or adaptor cables too many to make it worth it, They would also have to let the public know. I'll let ben know on the dot net 2 problem your having and see what he can help you with on that. BTW you cable should ship monday. If you want a car adaptor with yours along with the home power email me I'll throw one in.
    James Tune
    CEO, Co Founder
    Hybrid Mobile Solutions, Inc
  2. #142
    May 2004
    NJ
    @R32 JUhl: looks like you have SW issue on your PC, Frodo's test takes a bit of time but not 2 min. Don't dismiss the possibility that one or more of the pins is lose. Oh, if you got that far with Indigo & Frodo test, then xmd is fine and responding to power-on. try to start cold and see if you can get eXem to work. Your issue could be drivers.
    SinnerG: I think you are using the Hybrid cable, correct, if that is the case, then your issue is also SW related. Your issue could be setup related.
    .NET should not take long to install, are you guys sure that your setup is up to date, all fixes and whatnot.
    Just a thought, go to device manager, make sure that you have only one "mouse" installed, XP could be a smart *** at times.
  3. #143
    Maximum Bitrate R32 JUhl's Avatar
    Nov 2004
    North Atlanta
    Quote Originally Posted by Imagex
    They would have to change many headunits or adaptor cables too many to make it worth it, They would also have to let the public know..
    It was wishful thinking, on my behalf.
    It's a ****er! I tried to uninstall and it said that it would not let me. So I downloaded a fresh install from Microsoft and it wouldn't let me install because it said there was already a version on my machine. So I tried to use its uninstaller to remove that version PLUS I removed .Net 1.1 and it STILL wouldn't let me remove it or install new. But I have reinstalled .NET 1.1. All that happened this morning before my problems started.
    THANKS for your help!
    My first attempt at a carputer.
    PM me if you're interested in a monitor faceplate for your '99-'04 Golf or Jetta. My Vortex ID is NorthAtlR32 - you can IM me there, too. Go here for more information.
  4. #144
    Nov 2004
    North Atlanta
    Quote Originally Posted by kingtut
    I'm leaning toward a loose pin in the cable I built. As for the cold-start, it never worked with testxm, but it did work once with the com port emulator - but only once. All other times it was only after a previous plugging/unplugging of +12V. As far as drivers are concerned, I'm having the issue on two computers - one 2000 and one ME - but I suppose it could still be drivers.
    .NET should not take long to install, are you guys sure that your setup is up to date, all fixes and whatnot..
    Both computers have all of the latest updates from MS updates.
    @Just a thought, go to device manager, make sure that you have only one "mouse" installed, XP could be a smart *** at times.
    Even though I'm not running XP, I followed your advice... and there's only one mouse installed.
  5. #145
    Jan 2003
    Ruston, LA
    NOW, after following your advice to wait, I'm getting info from XMD1000
    001 XM Preview Preview
    247 Emergency/Alert Information Emergency Alert Special Events
    If that's all you got, your XM service isn't activated yet.
    But that's a secondary issue.
    Are you sure you have good reception ? Try moving your antenna.
    It should be facing south.
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
  6. #146
    Nov 2004
    North Atlanta
    Quote Originally Posted by frodobaggins
    Right! I'll activate about the time I'm ready to do the install. I've alread got two XM receivers activated - an old Sony Plug and Play model and a Roady 2.
    It's sitting in my southfacing kitchen window right next to another (much older) XM antenna that gets perfect reception in the same spot. What would the data look like if it was not getting a satellite signal?
    Oh, one more thing. A good friend works for XM and advised me that the Southern states have an easier time getting a signal due to the positioning of the satellites. The Northern states are facing the satellites at a greater angle.
  7. #147
    Jan 2003
    Ruston, LA
    I'll work up a more detailed test app later today. We can see what data we are getting.
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
  8. #148
    MySQL Error jcdillin's Avatar
    May 2003
    Miami, FL
    Yeah that would be really good for testing purposes.
    肚子笑痛了
    S60 Install
  9. #149
    Constant Bitrate SinnerG's Avatar
    May 2003
    Long Beach
    I got it working last night @ 3:30AM. For no rhyme or reason, I started seeing info. The ONLY thing I did differently was to completely power down my machine (Unplugged it from the wall for 30 mins). Right when I was about to call it quits, it started receiving the previews. I had to refresh my subscription, and all channels came through. Thanks all for the advice (Frodo, KingTut, ImageX, and the rest of yous)
  10. #150
    May 2004
    NJ
    One down, one to go
  1. Earthmate USB to Serial cable
    By New_Compact in forum GPS
    Last Post: 05-22-2008, 02:55 AM
  2. XMDirect Digital Audio Project ?
    By Retsaoc in forum General Hardware Discussion
    Last Post: 10-11-2004, 10:26 PM
  3. where should i go to get a cable?
    By blackpacu in forum LCD/Display
    Last Post: 09-08-2004, 01:25 AM
  4. A cable I found.
    By masterful in forum LCD/Display
    Last Post: 08-17-2003, 10:36 PM
