Page 3 of 23 FirstFirst 12345678910111213 ... LastLast
Results 21 to 30 of 222
Thread: XMDirect Cable
  1. #21
    Variable Bitrate hevnsnt's Avatar
    Mar 2004
    www.i-hacked.com Hardware hacking articles
  2. #22
    Maximum Bitrate GruvThang's Avatar
    Jul 2004
    Northern Virginia, USA
    very nice pic
    [COLOR=Navy][SIZE=1][FONT=Comic Sans MS]Tektility
  3. #23
    Maximum Bitrate Hcomplyr's Avatar
    Nov 2003
    Salem MA USA
    XM will have a new member in a few weeks
  4. #24
    Aug 2004
    Leawood, Kansas
    any other place to find one of these mini din extension cables? I'll go buy an XM direct tom. If I can find a cable to cut up.
    Compaq v6719 Athlon X2 tk-57
    Xenarc 7" Dash Install, iGuidance w/ iGPS 500
    HD Radio, Powermate, ShuttleXpress, XMDirect, DC/Auto turn on, Pioneer TS-C720PRS, 2 12" MTX BTE's, JL 500/1 and RBC
    94.3% of all percentages are made up
  5. #25
    MySQL Error jcdillin's Avatar
    May 2003
    Miami, FL
    if you can ask around for a old mac printer cable it will do the job.
    肚子笑痛了
    S60 Install
  6. #26
    Aug 2004
    Leawood, Kansas
    I just made this cable, called and activated my XM direct. I have tested all the pins to make sure they are all correct. I activated my com port in my bios. It's set to com 1. Baud 9600. Frodo goes to the xm screen but doesn't do anything when I click on xm. I made sure that the video lockout/ everything else is all set to a dif. port. I downloaded and installed the hybrid exem software. the exem software says xm direct not found. Does the common ground need to be hooked up? What else can i try..... Help!
    Thanks in advance
  7. #27
    May 2003
    Miami, FL
    Do you have the 2 grounds connected together?
    Also try setting your serial port speed higher, I think I have mine set at 115200. I dont think it matters though.
    肚子笑痛了
    S60 Install
  8. #28
    Aug 2004
    Leawood, Kansas
    pin 8 and pin 3 grounds? I did it just like the diagram edited by hevnsnt
    and no they aren't connected together...
  9. #29
    Aug 2004
    Leawood, Kansas
    I ended up solving the problem (I think) by connecting the shielding cable on both wires together. As soon as I touched them, frodoplayer pulled in all the channels. Checked out all the channels on my drive home.
  10. #30
    May 2003
    Miami, FL
    So you have the outside of the DB9 connected to the shield of the 8 Pin Mini-Din?
    肚子笑痛了
    S60 Install
  1. Earthmate USB to Serial cable
    By New_Compact in forum GPS
    Last Post: 05-22-2008, 02:55 AM
  2. XMDirect Digital Audio Project ?
    By Retsaoc in forum General Hardware Discussion
    Last Post: 10-11-2004, 10:26 PM
  3. where should i go to get a cable?
    By blackpacu in forum LCD/Display
    Last Post: 09-08-2004, 01:25 AM
  4. A cable I found.
    By masterful in forum LCD/Display
    Last Post: 08-17-2003, 10:36 PM
