Page 4 of 23 FirstFirst 1234567891011121314 ... LastLast
Results 31 to 40 of 222
Thread: XMDirect Cable
  1. #31
    Variable Bitrate hevnsnt's Avatar
    Mar 2004
    Is my diagram correct? I will make any changes if needed..
    www.i-hacked.com Hardware hacking articles
  2. #32
    MySQL Error jcdillin's Avatar
    May 2003
    Miami, FL
    No it is correct, we just need to put it on the image that the view shown is looking at the end of the cable. I tested it against my cable last night just to make sure. And it's fine.
    肚子笑痛了
    S60 Install
  3. #33
    Mar 2004
    hmm.. Then I don't understand nickmig's prob...
  4. #34
    May 2003
    Miami, FL
    His problem is fixed, what he did was ground the shield on the cable. So I guess we should add a shield connection to that diagram
    肚子笑痛了
    S60 Install
  5. #35
    Raw Wave god_of_cpu's Avatar
    Jan 2004
    SilverSpring Maryland
    Sweet!!! I'm gonna use this cable for $6 http://www.buy.com/retail/product.asp?sku=10030618&loc=
    StreetDeck.com Developer (I am Chuck)
    Get StreetDeck at http://www.streetdeck.com
    The Official StreetDeck Forums have moved, please visit us at http://www.streetdeck.com/forum for official support for Streetdeck.
  6. #36
    May 2003
    Miami, FL
    thats perfect. just make sure you ground the shield on the cable!
    肚子笑痛了
    S60 Install
  7. #37
    Aug 2004
    Leawood, Kansas
    actually it isn't fixed...sometimes it works and sometimes it doesn't. I just shortened the cable thinking that that was the problem....no go, it is still intermittent...F***ing A!!
    edit: I actually used a belkin 6' mac serial printer cable... The new cable is about a foot and a half
    Suggestions???
    Compaq v6719 Athlon X2 tk-57
    Xenarc 7" Dash Install, iGuidance w/ iGPS 500
    HD Radio, Powermate, ShuttleXpress, XMDirect, DC/Auto turn on, Pioneer TS-C720PRS, 2 12" MTX BTE's, JL 500/1 and RBC
    94.3% of all percentages are made up
  8. #38
    May 2003
    Miami, FL
    you are using take3 right? did you end up using the USB adapter or your onboard serial port?
    肚子笑痛了
    S60 Install
  9. #39
    May 2003
    Miami, FL
    Quote Originally Posted by nickmig
    Suggestions???
    Did you ever get this resolved?
    肚子笑痛了
    S60 Install
  10. #40
    Mar 2004
    I have built several using the above diagram and all work perfect.. My guess is one of your solder joints is bad (if you are still having the problem)
    Since I don't have access to any of the other XM devices.. Does anyone know if this cable ONLY works with the XMD1000 or does it work with others (like the roady etc)
  1. Earthmate USB to Serial cable
    By New_Compact in forum GPS
    Last Post: 05-22-2008, 02:55 AM
  2. XMDirect Digital Audio Project ?
    By Retsaoc in forum General Hardware Discussion
    Last Post: 10-11-2004, 10:26 PM
  3. where should i go to get a cable?
    By blackpacu in forum LCD/Display
    Last Post: 09-08-2004, 01:25 AM
  4. A cable I found.
    By masterful in forum LCD/Display
    Last Post: 08-17-2003, 10:36 PM
