Page 6 of 23 FirstFirst 12345678910111213141516 ... LastLast
Results 51 to 60 of 222
Thread: XMDirect Cable
  1. #51
    Clover Grayscale's Avatar
    May 2004
    Arkansas
    yeah, just soldered the serial cable directly onto the place where the 8 pin din socket was cause i couldn't find any cables for it anywhere...and guess what? i start exem and it says xm radio cannot be find. i tried frodoplayer also. are there any lights this thing will have to show its on or anything?
    CarPC install is starting to come along again...
  2. #52
    MySQL Error jcdillin's Avatar
    May 2003
    Miami, FL
    No, that is the only thing I dont like about it, I am going to mod mine and install a power light.
    肚子笑痛了
    S60 Install
  3. #53
    May 2004
    Arkansas
    woah its working!!! some reason the red wire on my psu was putting out 12v and the yellow wire was putting out 5v. am i just stoned or isn't it supposed to be the other way aruond? i think maybe its because i had a little y-splitter cable. oh well, off to go play!
  4. #54
    May 2003
    Miami, FL
    lol uhm, might not want to run your mobo off that PSU
    should be red 5v+ yellow 12v+
    肚子笑痛了
    S60 Install
  5. #55
    May 2004
    Arkansas
    i know, thats what made me mad cause i was freaking out thinking i did this wrong. the y-splitter cable had yellow wire in the 5v spot and i was tapping off of it. stupid cheap cable! lol i was like damn im not that bad at soldering. i took a few pix of my direct solder job if anyone wants to see Lol i was using hvnsents diagram and at first i soldered everything up backwards because i forgot he was showing the diagram for a cable and i was soldering onto where it would have been a plug! Oh well. right now its just got 2 chans. 1 is xm preview and then the other is emergency. and then in xm preview it changes the channel its playing or something. its weird, i'm just gonna wait for a while cause i think its normal
    edit: YES this is so awesome!
  6. #56
    May 2003
    Miami, FL
    Did you get all the channels?
    肚子笑痛了
    S60 Install
  7. #57
    May 2004
    Arkansas
    Yep! I was doing this inside my house though and the window i had the antenna by was facing the east haha. So yeah, it wasn't getting a good signal. I got the list and then i could play music for a sec then lost signal. And then I didn't get any music on the lower numbered channels. But then like The Move and higher channels like that I could get. Kinda weird. I'm gonna play with it in my car tonight, I just didn't have time to try to get a good 12v source from my car computer (im gonna have to modify my custom case)
  8. #58
    May 2003
    Miami, FL
    yeah I found if the antenna wasnt getting any signal from the sat and only from the ground antenna, that it wouldnt give me anything but the preview channel, as soon as I put it into the car every channel came up.
    肚子笑痛了
    S60 Install
  9. #59
    May 2004
    Arkansas
    Yeah, just put it into the car and its getting a great signal
  10. #60
    May 2003
    Miami, FL
    Great to hear.
    肚子笑痛了
    S60 Install
  1. Earthmate USB to Serial cable
    By New_Compact in forum GPS
    Last Post: 05-22-2008, 02:55 AM
  2. XMDirect Digital Audio Project ?
    By Retsaoc in forum General Hardware Discussion
    Last Post: 10-11-2004, 10:26 PM
  3. where should i go to get a cable?
    By blackpacu in forum LCD/Display
    Last Post: 09-08-2004, 01:25 AM
  4. A cable I found.
    By masterful in forum LCD/Display
    Last Post: 08-17-2003, 10:36 PM
