Page 7 of 23 FirstFirst 1234567891011121314151617 ... LastLast
Results 61 to 70 of 222
Thread: XMDirect Cable
  1. #61
    Maximum Bitrate R32 JUhl's Avatar
    Nov 2004
    North Atlanta
    So, back to the discussion of a serial to USB adapter. I bought the adapter cable for $25 + tax - OUCH!!!! And I'm getting ready to build my Din to Serial cable as per your instructions. And I'm wondering why I would do that? Why not build a DIN to USB cable instead and skip the middle man, so to speak? That way I can return the $25+ cable and eliminate one more possibility for a an electrical connection problem later on.
    Would you be able to provide instructions on how to do that?
  2. #62
    May 2004
    NJ
    Quote Originally Posted by R32 JUhl
    cause it is cheaper this way. if you have serial port, then you are done and no need to do any thing else, if not, all you need is a serial->USB adapter. Din->USB = expensive & complicated, besides, it is still Din->serial->USB but under the hood.
  3. #63
    Nov 2004
    North Atlanta
    Quote Originally Posted by kingtut
    Sorry for asking, but why is it cheaper this way?
    if you have serial port, then you are done and no need to do anything else.
    I can certainly appreciate that. But my point is, if you haven't built ANY cable yet, then why is it more expensive and more complicated to build a DIN to USB cable? Consider my lack of knowledge of the internal workings of a USB cable!!!! It seems that you can build the DIN/USB cable as simply as you're building the DIN/Serial. Unless that Serial/USB cable has some super-duper adaptive internal interfacing abilities...? Is it doing more than just simply connecting some wires?
    Guess there is more at work than just a splicing of wires... Any knowledge you can pass along would be greatly appreciated by all us newbs and non-USB proficient individuals.
  4. #64
    May 2004
    NJ
    the xmdirect din output (pins 1,2 &3) is actually serial, you can't just connect serial to usb, you would need something like this PIC16C765 USB micro controllers to do the conversion. there is more to it than splicing wires.
  5. #65
    Nov 2004
    North Atlanta
    Ok. Thanks.
  6. #66
    MySQL Error jcdillin's Avatar
    May 2003
    Miami, FL
    That pretty much is the gist of it
    肚子笑痛了
    S60 Install
  7. #67
    Nov 2004
    North Atlanta
    Just finished building my cable. According to their website, the Brown Gorilla has left my XM Radio at my front door. I'll work on the install tonight and post progress. I was hoping I wouldn't have to use that $25 USB to Serial cable, but I now understand the only way around that is to use Com1.
    BTW, I have about four pages of FAQs answered/created. I haven't forgetten them - quite the opposite, really! They just keep growing and improving with each edit - 12th version so far.
  8. #68
    Clover Grayscale's Avatar
    May 2004
    Arkansas
    sweet, you should post that! FAQ's of random carputer information? i'll post pix of my direct connection to a serial cable too! I bypassed the 8 pin din connector since i couldn't find one anywhere, works great tho! Expect pix later tonight probably
    CarPC install is starting to come along again...
  9. #69
    May 2003
    Miami, FL
    very cool on both of those!
    肚子笑痛了
    S60 Install
  10. #70
    Nov 2004
    North Atlanta
    Quote Originally Posted by Grayscale
    Some random computer questions, but most are carputer specific with how to's that should be posted in MP3Car's FAQ section. Thanks for the support.
  1. Earthmate USB to Serial cable
    By New_Compact in forum GPS
    Last Post: 05-22-2008, 02:55 AM
  2. XMDirect Digital Audio Project ?
    By Retsaoc in forum General Hardware Discussion
    Last Post: 10-11-2004, 10:26 PM
  3. where should i go to get a cable?
    By blackpacu in forum LCD/Display
    Last Post: 09-08-2004, 01:25 AM
  4. A cable I found.
    By masterful in forum LCD/Display
    Last Post: 08-17-2003, 10:36 PM
