Page 1 of 23 1234567891011 ... LastLast
Results 1 to 10 of 222
Thread: XMDirect Cable
    MySQL Error jcdillin's Avatar
    May 2003
    Miami, FL
    XMDirect Cable
    Well after a couple days of playing with the XMDirect tuner, and doing some research I have been able to make my own cable for attaching the XMD1000 to your PC so you can control it using your serial port using frodoplayer.
    It's actually quite simple first you need to find either a 8 pin mini-din plug or a old style mac printer cable.
    Then you just attach the pins from the 8 pin din to the following pins on a 9 Pin DSUB Connector using the pinouts below.
    XMD -- DB9 Serial
    pin 1 = pin 3 Data Receive
    pin 2 = pin 2 Data Transmit
    pin 3 = pin 5 Ground
    Then after you have those connected you just need to find a source of power which can come from your PC power supply. Pinouts below.
    XMD -- Power supply
    pin 6 = 12v
    pin 7 = 12v
    pin 8 = gnd
    And that is pretty much it. Works perfectly with frodoplayer.
    Images of the pinouts below.
    肚子笑痛了
    S60 Install
    Bowel movement jjh221's Avatar
    Dec 2003
    not sure yet.
    one of these days ill have to get XM
    I GIVE FREE HUGS!
    Buy Sell or Trade
    If my pm box is full, please feel free to call me any time. 440-328-3382
    Thank you
    Forex
    Rate Mp3car @ FXroot.com
    May 2003
    Miami, FL
    it's worth the $10 a month
    肚子笑痛了
    S60 Install
    Newbie Compu-Blazer's Avatar
    Oct 2004
    Spring Grove Illinois
    is this the same type of cable that is being sold in the mp3car store for 50 bucks?
    CarPc Done.
    HA HA......Is it ever done?
    Dec 2003
    not sure yet.
    What cable are you talking about? I didnt see one for 50 bucks
    I GIVE FREE HUGS!
    Buy Sell or Trade
    Thank you
    Forex
    May 2003
    Miami, FL
    Quote Originally Posted by Compu-Blazer
    I didnt know the mp3car store was selling one, but this is the same cable that hybrid mobile is selling.
    肚子笑痛了
    S60 Install
    Low Bitrate Imagex's Avatar
    Jun 2004
    if you want to add status lights for transmit and power use a 200 ohm resistor to a LED hooked to pin 3 and for power use a 500 ohm to another led.
    James Tune
    CEO, Co Founder
    Hybrid Mobile Solutions, Inc
    Oct 2004
    CarPc Done.
    Constant Bitrate e_z_street's Avatar
    Feb 2004
    Did you send it the magic word to switch it to pcr mode?
    Variable Bitrate kmcniece's Avatar
    Aug 2004
    Portland, Oregon
    wha........?
    Quote Originally Posted by e_z_street
    part of me REALLY hopes you are kidding......
    EPIA M10000, 512 Ram, Opus 90, GPS, XM, 7" Xenarc, Pioneer HU
    Status:
    Installed & Working....
    Custom enclosures
    Newbie Guide
  1. Earthmate USB to Serial cable
    By New_Compact in forum GPS
    Last Post: 05-22-2008, 02:55 AM
  2. XMDirect Digital Audio Project ?
    By Retsaoc in forum General Hardware Discussion
    Last Post: 10-11-2004, 10:26 PM
  3. where should i go to get a cable?
    By blackpacu in forum LCD/Display
    Last Post: 09-08-2004, 01:25 AM
  4. A cable I found.
    By masterful in forum LCD/Display
    Last Post: 08-17-2003, 10:36 PM
