Page 1 of 3 123 LastLast
Results 1 to 10 of 27
Thread: Auto activate backup camera
    SWC
    SWC is offline
    Aug 2004
    Baltimore
    I am looking for a way to interface a backup camera so that when the car is in reverse it will automatically go to the backup cam screen. I know how to wire it into the car (pretty easy actually) just need to hook it into the backup lamp wire. But what is an easy and fairly inexpensive way (I.E. No phidgets since a solution would be like $100+ probably) to have the computer determine when the circuit is turned on so that it can activate the backup cam.
    Maximum Bitrate kiltjim's Avatar
    Feb 2004
    PA, USA
    The software that I am trying to develop for this board here. will do it.
    Otherwise, without the board, it would take a very little script, or FrodoPlayer to do it. And the trigger would be wired into the serial port.
    2000 Subaru OBS
    Dell P3 @ 900 Mhz
    7" Lilliput TS w/DigitalWW in-dash mount
    80GB External HD
    I am Zero Bitrate....
    Variable Bitrate Dracos's Avatar
    United Kingdom
    well, a relay i guess. ummm, a relay with software?
    eg, 12v from rear illumination (reverse lamp) turns on relay, closes a switch, turning the camera on.
    software determines when camera is turned on, and cuts to cam view when it is on
    that is easy, you just gotta get someone to wrie the software
    on that note, you could have a kinda double circuit. what I said above, except the relay is a SPDT relay, closing a switch turning the cam on, and shorting 2 pins on the comp/LPTI port. the shorting of the 2 pins would launch your rearview app, or would act at a 'hotkeyy press' for whatever you want. speak to weekendowel, i know he can do software like that.
    My Village Called 0l33l's Avatar
    Jul 2004
    Berkeley, CA
    Well, you could ask the person who wrote the software for when doors are open to add a sensor to the serial port that detects if two pins are shorted (when you have the backup light).
    SWC
    SWC is offline
    Aug 2004
    Baltimore
    Depending on how expensive the serial option is that might be worth a shot, writing the software isn't a problem. I decided to take a look at phidgets for just the voltage sensor its $17US. Not too bad the USB interface is the expensive part but may not be too hateful if I decide to hook it up to my AC and control that as well. It would bring the cost to $68 plus the cost of the servos for the AC. so total cost of controlling AC and rear cam would be about $122.
    United Kingdom
    Quote Originally Posted by 0l33l
    lol! I already told him to do that
    Jul 2004
    Berkeley, CA
    Quote Originally Posted by Dracos
    You said LPT port, I said Serial
    United Kingdom
    psh - effectively the same method (although what i meant was about asking owel )
    Jul 2004
    Berkeley, CA
    United Kingdom
    now thats just spamming lol
  1. Auto reverse camera
    By Tha Hombre in forum General Hardware Discussion
    Last Post: 10-10-2008, 03:30 AM
  2. Replies: 29
    Last Post: 04-09-2007, 06:44 PM
  3. Backup Camera Screenshots, please.
    By Zoltan in forum General Hardware Discussion
    Last Post: 09-05-2004, 08:52 AM
  4. For Sale, 1 x Wireless Miniature Security Camera.
    By buildfromscratc in forum Classified Archive
    Last Post: 07-15-2004, 07:13 PM
  5. Great working tank circuit with backup bat.
    By NightHunter in forum Power Supplies
    Last Post: 04-29-2004, 10:51 PM
