+ Reply to Thread
Results 1 to 6 of 6
Thread: 3 conductor 2.5m mini plug
    Constant Bitrate DrStein99's Avatar
    May 2004
    Audubon, NJ
    I am using a pvr-a1, which is a personal digital video recorder. The a/v in is a 2.5m 3 conductor jack.
    I need to make a right angle connector, or something else. The cable supplied from manufacturer sucks.
    Does anyone have any links or resources for 2.5m plugs? I want to solder my own or get a right angle adapter.
    It's smaller than a standard headphone jack. also I am running video and audio, so its 3 CONDUCTORS and not just two (stereo).
    Looking for an electric component supply place, please thanks.
    www.RAIDGEAR.net Engineering :: Research, Development and Art - all is one www.DrStein99.com
    Low Bitrate TechToy's Avatar
    sure it's 3 conductor... or 4 conductor don't forget ground...
    R+L+V+G
    try here..
    http://www.kenselectronics.com/lists/audio.htm
    also did a little poking... the nokia HDD-1 headset comes with one of those plugs AND a right angle plug... you may want to do a little surgery and adapt it to what you want to do.. and e-bay has LOADS of them listed for dirt cheap... search for HDD-1
    again assuming it is 4 conductor.. tip-ring-ring-sleeve
    TechToy
    2005 Explorer
    Proudly using Centrafuse
    DWW-700M + Sony XM-SD46S &
    pre-amp, XM100D
    and Icom PC1000
    Yaesu 7100M
    Kenwood TM-641
    FLAC ukchris's Avatar
    Nov 2003
    Massachusetts
    May 2004
    Audubon, NJ
    Quote Originally Posted by ukchris
    ukchris - thanks for the info. I've found that site. It offers only stereo or mono jacks.
    I need at least 3 conductors, for stereo and video. Also, the LENGTHS of the plugs vary. So I need to get samples to pursue the compatibility.
    Right now I am at a standstill, but the link from TechToy helped alot - I'll order some from there. Still open to more links please, I could use as many as possible.
    May 2004
    NY State USA
    RadioShack has them, right angle 1/8th inch to three rca. The should be by the digital cameras midway though the store. You dont want one for a cell phone, that will most likely be too small, good luck!
    New car means time for a new carputer.
    Planing.
    May 2004
    Audubon, NJ
    Quote Originally Posted by trebuchetguy
    That is the final product. I am trying to buy the plugs myself to make my own cables. I need a right angle plug due to the space considerations.
    The one I seen at my local radio shack is too big (headphone size). The jack I need is a step down from standard headphone size of a soundcard, and handles THREE conductors.
    Radio shack doesnt seem to handle this in their stores, and online they seem to sell only a three conductor version that isnt right angle.
+ Reply to Thread
  1. Mini ITX in car stereo?
    By ljstevens in forum Newbie
    Last Post: 11-26-2004, 11:56 AM
  2. How the new Mini will work
    By frodobaggins in forum FrodoPlayer
    Last Post: 06-02-2004, 12:05 PM
  3. newbi 1st question - mini PC
    By dunkonu in forum General Hardware Discussion
    Last Post: 12-24-2003, 03:55 AM
  4. Replies: 5
    Last Post: 07-12-2003, 02:43 AM
  5. Mini Installation
    By Rob in forum Off Topic
    Last Post: 06-30-2002, 02:02 PM
