Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: A/V Cables
  1. #11
    Nov 2004
    you are right about that. i did have to increase th fint size. what i did was set the dpi to 120 but now the windows dont fit in the screen. so if i open up a config window in an app, only about half of the windows will be visable. know how i can fix this or what may have caused it?
  2. #12
    Maximum Bitrate sfay93's Avatar
    Feb 2004
    Omaha, NE
    Either deal with it or get a new monitor. Keep playing around with the settings until get find a happy medium. There are many posts on here dealing with that so I would search some of the monitor threads and read up what others have done.
    ATVMS.com
  3. #13
    Nov 2004
    but what about the main problem with the audio and video noise. i am sure running some kind of common ground would help. but how do i go about doing that withthe equipment i have?
  4. #14
    Feb 2004
    Omaha, NE
    I am not saying it won't help you but I have never ran a common ground. Noise could also be coming from your inverter. If it is a cheap one then it is definitely a suspect at least. Try running an extension cord out to the car to remove the inverter from the equation. Like I said, just go through the whole setup 1 piece at a time to eliminate each piece as a suspect. It can be time consuming but it is better than throwing money at the problem until you find the solution. That gets too expensive if you don't find the problem in the first couple of tries.
    ATVMS.com
  1. 5x XMDirect Cables $25/ea shipped.
    By hevnsnt in forum Classified Archive
    Last Post: 04-12-2005, 01:57 AM
  2. Replies: 3
    Last Post: 09-03-2004, 08:07 PM
  3. Custom Length Round IDE Cables
    By antimatter in forum General Hardware Discussion
    Last Post: 08-17-2004, 01:23 PM
  4. Running cables
    By skippy76 in forum General Hardware Discussion
    Last Post: 04-15-2004, 03:32 PM
  5. Where to get long high quality VGA cables....
    By psyclobe in forum General Hardware Discussion
    Last Post: 10-22-2003, 02:07 AM
