Just buying different cables will not reduce the noise in your system 99% of the time. Did you run power and signal wires on seperate sides of the car? Is your system grounded properly? These are the 2 most common causes of noise in a system.
well i am getting quite a bit of noise and i figure getting decent cables are the first step in eliminating it. here is a link to a site and what i dont get is that there are like 50 different types of monster video cables on 8 pages. so which ones should i get both for video and audio from my carputer and also xbox to my a/v switch?
link: http://www.futureshop.ca/catalog/sub...=2&catid=11343
ATVMS.com
they are run from different sides but i highly doub ti did groudn everything properly and this is because i guess nobody every responds to my threads. here is my set-up. xbox and shuttle pc, powered by 300 w inverter w/ 8 awg cable directly to the battery. pioneer HU with aux-inb adaptor and clarion lcd. both running to a a/v switch and then the pc and xbox a/v cables going into the switch. i am getting a lot of video noise and audio noise. i know you say i should have a common ground. but i am new to this and what type of wiring should i use for grounding, and how do i exactly ground a xbox or the shuttle. someone please help me out, a diagram would really be appreciated.
Do you get the noise from all components or just 1? If it is all, I'd suspect the a/v switch possibly. Try hooking each piece up directly without the switch just to test it out. I have used some pretty crappy cables (Dollar Store kind, they were temporary) before and never had a problem with noise so I would check everything else out before I spent the money on cables.
ATVMS.com
it is with all the stuff but it gets really bad with the pc. i even hear a buzzing noise come from the computers psu
Like I said, try the direct connection route with each of them to see if that improves your situation. What monitor are you using by the way?
ATVMS.com
i am using a clarion 5.8". i tried the direct connecting and the audio noise was still there, but the video noise went away quite a bit
no amps and what exactly from the pc will look crappy?
All of the print unless you use super big fonts. That screen is not a vga monitor. It is PAL/NTSC. If you read up on it here you willl get more info.
ATVMS.com
