Results 1 to 6 of 6
Thread: serial port switch input
    Dec 2004
    i have just installed my carputer in my 97 grand cherokee, and it has buttons on the sterring wheel for volume up down, and prev/next track, i have all the wiring to the computer for these switches, but i need a program that can see momentary switches on the serial port and convert them to keyboard presses so i can map them to mediaengine. is there anything like that out there?
    Low Bitrate Wolfman's Avatar
    Nov 2003
    East Texas
    I don't know...maybe hack a serial or even usb keypad and assign the buttons?
    My Village Called 0l33l's Avatar
    Jul 2004
    Berkeley, CA
    Maybe girder Also, search for I-BUS stuff... there's a guy who did some nice stuff with it. I beleive it was serial.
    Maximum Bitrate mushin's Avatar
    Aug 2004
    SE Michigan
    Does it have to be serial? An easy option would be to wire it up to a keyboard controller (PS2 or USB), and you won't need a program at all.
    If it has to be serial, and you can't find any existing software to do what you want, PM me and I can write up some code to do what you want. I might require a bit of bribing though
    Nov 2003
    Chicago
    I am using a serial port to recieve momentary switch input using girder with the serial switch plugin.
    Variable Bitrate silencery's Avatar
    Jul 2004
    Los Angeles, CA
    http://www.modasylum.com/guides.php?guide=21
    This should do the trick. The girder solution is better IMHO, highly recommeneded.
  1. Serial / Parallel / USB Port Programmers
    By owenjh in forum Software & Software Development
    Last Post: 12-16-2003, 02:11 PM
  2. IR serial port receivers
    By Fusion-One in forum Input Devices
    Last Post: 08-07-2003, 06:49 PM
  3. Where to get a serial port
    By infx708 in forum General Hardware Discussion
    Last Post: 02-12-2003, 11:53 AM
  4. Program or batch file to control DTR on a serial port
    By percyt2k in forum Software & Software Development
    Last Post: 12-17-2001, 04:41 PM
  5. ATX power switch
    By mtmsol in forum Power Supplies
    Last Post: 05-13-2001, 01:22 PM
