Page 3 of 3 FirstFirst 123
Results 21 to 24 of 24
Thread: temperature sensors
  1. #21
    Oct 2003
    I know this thread is a little old, but I'm trying to do the same thing. Momanz - if you're still around - where did you get the MAX chip, the adapter, and the thermistors?
    Thanks,
    Dan
  2. #22
    FLAC mauri's Avatar
    Jan 2004
    Use one DS18B20,one Pic uP,its easy....
    One link for make home made one hardware:
    http://www.rentron.com/pic.htm
    Mauri
  3. #23
    Jul 2004
    Dan, I got the chip from maxim as a sample. The adapter came from the link below and the sensor is actually a transistor (2N3904 NPN) not a thirmistor. The transistor is a fairly common one that you can find at most electronics stores or you can order them from glitchbuster.com shipping is under $2 for most orders.
    adapter ==> http://www.epboard.com/eproducts/pro...OPtoDIPAdapter
    If you've ever etched a cu board to create a custom PCB you don't need to buy the adapter. Be sure to use the staples inkjet paper as your transfer media. Search, there's a link somewhere on the site that will take you to a step by step instructions on etching cu boards.
    Good luck.
    momanz
    Carputer installed!!!
    Nlited XP+Minlogon, EpiaM10k, 512mb, Seagate 40 gig 2.5" HD, FM Dlink usb radio, DWL122 USB Wifi, XMD1000 tuner, PT5071 6 amp regulator, Xenarc 700TSV, and 1 ikea key box.
  4. #24
    Bah every one has to go writing there code in picbasic. Tisk Tisk are there no people out there that like ASM? At any rate I don't think I will have any problems writing some asm to make the sensor. If any one is interested I will release source when I'm done.
    I'm also going to see about using some of the A/D converters on the 16f88 to suport a few thermoresisters (they can handle very high temps) for monitoring exhast temps.
  1. Monitoring outside temperature
    By Tha Hombre in forum General MP3Car Discussion
    Last Post: 01-25-2006, 10:22 AM
  2. MPJA - MECI ASTEC DC-DC Converter
    By Luc in forum General Hardware Discussion
    Last Post: 11-22-2004, 10:31 PM
  3. LCD temperature range
    By jplev22 in forum LCD/Display
    Last Post: 04-14-2004, 10:19 PM
  4. Pc in the car and low autside temperature. ( winter time )
    By Goose in forum General Hardware Discussion
    Last Post: 12-25-2002, 11:28 AM
  5. Need help finding idle and temp sensors
    By wizardPC in forum Off Topic
    Last Post: 05-07-2002, 12:40 AM
