Page 1 of 3 123 LastLast
Results 1 to 10 of 24
Thread: temperature sensors
    Newbie frankz's Avatar
    Dec 2004
    Atlanta
    temperature sensors
    here's a couple links for anyone who might like to add
    temperature sensors to their car, connected to your carpc:
    http://www.lancos.com/webtherm.html
    http://www.riccibitti.com/pc_therm.htm
    for the sensors (ds1631),
    Dallas Semiconductor was taken over my Maxim IC
    maxim-ic.com
    you can get a couple of them for free, by requesting free samples.
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    This is what I really want for a car PC temp sensor
    http://www.cesko.host.sk/GamePortTemp_eng.htm
    But I can't find those sensor in the States
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
    My man uses Levitra. Peoples's Avatar
    Dec 2004
    Maryland
    http://www.its-about-time.com/htmls/...atempsens.html
    this one looks pretty neat
    i bunch of them i've looked at retail at over $160, which IMO is rediculous, but $40 aint bad
    PC Components:
    My work log
    Variable Bitrate egeekial's Avatar
    May 2004
    Maximum Bitrate Skipjacks's Avatar
    Dec 2004
    Baltimore, Maryland
    Wait a minute....there are about 8 million temperature sensing computer products designed for monitoring case temp, processor temp, RAM temp, disk temp, mouse temp, keyboard temp, porn site temp, etc etc etc....
    One of those kind of things has to able to be converted easily and cheaply into an ambiant outside air temperature sensor.
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Heck, I just use a 4 sensor serial circuit that requires no external power and no calibration (US$30), it is fully incorporated into my remake of Media Car... check out:
    http://guino.home.insightbb.com
    (there are links for the information and ordering locations on the links page)
    Jul 2004
    This looks like the way to go. You basicaly get as many sensors as you want and it uses the SMbus (I2C) connector on the epia boards. One IC and you have 4 remote temp sensors 2 ICs 8 etc and the actual temperature sensor is a simple el-cheapo transistor. Best of all you don't use up a serial port.
    SWC
    SWC is offline
    Aug 2004
    Baltimore
    Quote Originally Posted by egeekial
    Phidgets are great but their temp sensor seems a lot bigger than most of the other around.
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by momanz
    That's awesome! although, with all my clumsiness and luck I'd probably fry my MB trying to get it in place.
    Jul 2004
    Actually most mobo's have a 5 or 6 pin header that you connect a cable to. That way you can build the circuit on a breadboard plug in and go. Now if you don't have an SMbus/I2C connector you will need to solder a connection to your motherboard. I'm thinking that the most difficult thing here will be soldering the leads to the chip, it's tiny.
    I'm waiting on parts to try this out. I'll post the results when I'm done.
  1. Monitoring outside temperature
    By Tha Hombre in forum General MP3Car Discussion
    Last Post: 01-25-2006, 10:22 AM
  2. MPJA - MECI ASTEC DC-DC Converter
    By Luc in forum General Hardware Discussion
    Last Post: 11-22-2004, 10:31 PM
  3. LCD temperature range
    By jplev22 in forum LCD/Display
    Last Post: 04-14-2004, 10:19 PM
  4. Pc in the car and low autside temperature. ( winter time )
    By Goose in forum General Hardware Discussion
    Last Post: 12-25-2002, 11:28 AM
  5. Need help finding idle and temp sensors
    By wizardPC in forum Off Topic
    Last Post: 05-07-2002, 12:40 AM
