Results 1 to 10 of 16
Thread: Can someone tell me what Kind of Circuit I need to build for this to work
    Nov 2004
    Can someone tell me what I need to make something keep voltage from going 2 ways in a wire.
    Here is the setup of the problem.
    I have a USB 2.0 Hub wired directly to the 5v line on my computer power supply, my problem is that when the computer is turned off, the lights on the CD-Rom, HDD LED and Power Led would all light up, as they were being powered from this 5v line back through the USB cable into the case.
    Does anyone know some type of Diode, Resistor or some other form of electrical part that I could purchase and Place on the wire, so that the power will not flow back through the cable into the 5v line. I am pretty sure that the Power is flowing from the USB Ports, through this Hub and then back into the 5v line of the Power Supply, which is then supplying power to the leds mentioned above.
    If I remove the Power Plug from the USB hub, then the Leds mentioned above no longer light up, so I am trying to stop the back flow of power into the Power Supply.
    Thanks for any help,
    Bryan
    2000 Yukon Denali
    Shuttle SN65G2
    Cel-D 2.4 GHZ 533mhz FSB
    1GB PC800 Mem
    Radeon9200 PRO
    Seagate 120GB
    ATI Remote
    RF Mini Kb w/Trk Ball
    7" Lilliput Touch Screen Monitor
    USB 2.0 Hub
    Rikaline GPS-6010
    PN11 802.11b Wireless
    XP Pro
    750W Inverter
    Maximum Bitrate kiltjim's Avatar
    Feb 2004
    PA, USA
    You need a simple diode "pointing" to the hub from the computer on the host(?) cable. That should solve your problem.
    However, with all diodes, they have voltage drop across the connection. I don't know if that is going to be a problem. I don't think it should, since the hub is going to be recieving data over the data lines, not the 5 volt line.
    2000 Subaru OBS
    Dell P3 @ 900 Mhz
    7" Lilliput TS w/DigitalWW in-dash mount
    80GB External HD
    I am Zero Bitrate....
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    How about a relay?
    Use the PC power (5V or 12V from the drive connector) to power the relay. The relay then connect or disconnect the "power" to the USB hub base on whether the PC is on or off.
    Make sense?
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
    Nov 2004
    Frankfurt am Main / Germany
    I think the diode is the cheaper and easier way...
    Maximum Bitrate starfox's Avatar
    May 2002
    Australia
    Yeah just buy a schottky diode (A power diode might drop the voltage a little too much). You'll need to take apart the USB cable running from the motherboard to the USB hub and put the diode in series with the V+ line. Make sure the diode's facing the right direction.
    anyone run into problems with the 0.7 Volt drop across a diode?
    May 2002
    Australia
    Schottkys have a lower voltage drop (0.2V to 0.3V), and should give you less problems in this situation where 0.7V is quite a bit.
    MySQL Error Scouse Monkey's Avatar
    Mar 2004
    Bristol
    What else is the difference between a normal and shottky diode? i used to use them on the motors of my RC cars. Also what is the difference with a zener?
    May 2002
    Australia
    Schottkys have a lower dropout voltage, but may have a higher reverse bias current leak.
    Have a look at this page, i think it summarises things well:
    http://www.play-hookey.com/semicondu...ed_diodes.html
    Feb 2004
    PA, USA
    A zener diode only allows current to flow if the voltage is higher than the listed value.
    2000 Subaru OBS
    Dell P3 @ 900 Mhz
    80GB External HD
  1. Replies: 3
    Last Post: 12-07-2004, 07:01 PM
  2. Remote Shutdown Circuit - Would This Work?
    By owenjh in forum Power Supplies
    Last Post: 09-01-2004, 10:43 PM
  3. Replies: 2
    Last Post: 09-12-2003, 06:29 PM
  4. Special audio preamp circuit
    By claylong in forum General Hardware Discussion
    Last Post: 01-14-2003, 05:19 PM
  5. Will anyone build me a tank circuit?
    By bombboyer in forum General Hardware Discussion
    Last Post: 11-08-2002, 11:47 AM
