Results 1 to 4 of 4
Thread: Audio Connections?
    Mar 2004
    Audio Connections?
    I am looking at adding some audio inputs to a custom panel near the front of my vehicle. I found this at digikey, but have no idea which to get. I would like a regular stereo audio input, like a headphone type jack. Also, if I wanted one stereo RCA jacks, how should i do that?
    Maximum Bitrate Marsupial's Avatar
    Feb 2004
    I would suggest you start by choosing what connection you want, then you can select the proper connectors.
    its all a matter of preferences.
    I myself like the headset connectors, but some other prefer custom-made. Its very different from one another.
    Mar 2004
    Yea... I am going to have one headset connector for extending the audio input from my motherboard and one rca setup for my Xenarc. I was thinking of having a stereo rca audio connection visible with a device that would switch it to headset. Either that or just have a cable that converts from headset to rca, which i already have.
    Main issue is what type of audio headset connector to get
    Jan 2005
    Edinburgh, Scotland
    You want fig. 69, part number cp-63516-nd for running a mini jack type headphone plug (3.5mm)
    I don't see any 1/4" panel mount sockets there, these are the larger connections. I would try and source high quality sockets, as the time that is taken in wiring up a socket is much more than the value of even an expensive socket.
    1/4" is also more robust if you use quality components. I think Neutrik do some nice locking jack sockets. Check this out Jacks / Locking 1/4" Chassis Jacks - Mates with all mono or stereo plugs specified to EIA RS 453 dimensionally compatible with D-series.
  1. OEM Navigation Connectors
    By Mr Castulucci in forum General Hardware Discussion
    Last Post: 07-20-2010, 05:25 PM
  2. Replies: 19
    Last Post: 12-04-2004, 05:37 PM
  3. XMDirect Digital Audio Project ?
    By Retsaoc in forum General Hardware Discussion
    Last Post: 10-11-2004, 09:26 PM
  4. XMDirect Digital Audio Output ?
    Last Post: 10-11-2004, 08:10 PM
  5. Seperate VGA and S-Video with Audio
    By Fox_Mulder in forum General Hardware Discussion
    Last Post: 07-01-2004, 01:44 AM
