Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: Need help fast please!
  1. #11
    Constant Bitrate old_lou's Avatar
    Oct 2004
    UK Midlands
    Tut Tut there you go again torching a n00b just because his spelling isn't up to standard.
    EPIA MII: 512m Ram: LinITX 8" Touch Screen: Carnetix P1290 PSU: 802b PCMCIA Wireless card: Slot DVD Player: Touchpad: Wireless Keyboard: BU303 GPS Mouse:
    Win 2000: RoadRunner Front End: Michelin Mapstore GPS: Netstumbler:
  2. #12
    Jan 2003
    Ruston, LA
    Quote Originally Posted by old_lou
    you couldn't read it either I assume
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
  3. #13
    Oct 2004
    UK Midlands
    I can after a fashion read it. I thought perhaps his native language wasn't English but he 's using slang like cuz so I am proberly wrong. I think the answer is, as said before, try a proper cable first then when you know its a runner you can work on bodgeing (sorry I mean readjusting) the cable connections. Also I seem to remember from work, where I usually had to connect up a cd to load something onto a hd only setup then forget to recover my CD from the stock CD Drive, that a CD drive only needs the power plug to open and not the IDE?
    As an aside I notice he's using nested brackets (a coder?)god help us if he asks about one of his scripts.
  4. #14
    Maximum Bitrate Change's Avatar
    Aug 2004
    California
    I wonder if the "50 pin IDE connector" is really a SCSI connector.
  5. #15
    Sep 2003
    Northern Va
    My thoughts exactly. First off, properly identify the drive. if it has jumpers for master/slave it is an IDE drive. If it has jumpers for a terminator, paridy, and jumpers of the 2^x, then it is SCSI. If it is SCSI, you need a SCSI controller. If not, take a pic of that messed up config, and use better grammer.
  6. #16
    FLA gospeed.racer's Avatar
    Dec 2003
    Portland, OR
    come on guys, he said he needed it FAST.....be FASTER with your comments....geeze!
    2005 Ford Focus ST
  7. #17
    My man uses Levitra. Peoples's Avatar
    Dec 2004
    Maryland
    this is pretty old by now, and i know this guy opened another thread under a different user name. That thread was as bad as this one.
    PC Components:
    My work log
  8. #18
    Newbie Gamefanatic's Avatar
    Jan 2005
    Well if it's a 50pin Connector which looks something like a 44pin IDE connector it is most definately a SCSI Connector. There is no "standard" specification for a 50pin IDE.
    Sounds like were trying to plug the square into the round hole here..
  1. Music track fast forward bug
    By Bootbox in forum CF Bug Reports
    Last Post: 12-06-2004, 11:22 AM
  2. Replies: 3
    Last Post: 09-28-2004, 02:13 AM
  3. Athlon Or Pentium ?? DVD, Navigation, GPS, Wardriving, MP3's... Fast boot
    By Cruznlife1 in forum General Hardware Discussion
    Last Post: 09-19-2004, 07:08 AM
  4. usb fast enough?
    By ShinkunoNamida in forum General Hardware Discussion
    Last Post: 06-02-2002, 02:52 AM
  5. Fast and the Furious (Arby please read)
    By hornet in forum Off Topic
    Last Post: 03-17-2002, 04:26 PM
