Page 67 of 78 FirstFirst ... 17575859606162636465666768697071727374757677 ... LastLast
Results 661 to 670 of 773
Thread: HU Quality AM/FM RDS/RBDS Radio with Features
  1. #661
    Mar 2005
    rds its not only showing infos. rds is also used for TA - tune automatic to alternative frequencies. also tmc data is transmitted over rds. so rds is for me a MUST for in-car use mainly ´because i don't want to tune my radiostation manual when the reception gets bad.
  2. #662
    Jun 2005
    Has anyone considered integrating this module?
    It's made by RadioScape and is intended to be integrated with mobile devices to tune AM, FM, DAB, DRM, RDS, etc. The spec shows that it has USB, I2C, and S/PDIF interfaces. It also states that it's designed to be controlled either by a PC or C.
    Looks like someone's already solved the problem.
  3. #663
    Maximum Bitrate pyros's Avatar
    Mar 2004
    Toronto, Canada
    Reading the info in the link, it doesn't look like it supports RDS but otherwise seems promising.
    2004 Ford Mustang Mach 1
    Specs: Epia M2-1000, 512mb ram, SB Audigy NX, Lilliput 7" Touchscreen, M2-ATX, DVD, 160gb HDD, gps, obdII, wifi, bluetooth, XM radio, HQCT and Logitech wireless gamepad.
    Install Status: DONE
    My XM FAQ
  4. #664
    Mar 2005
    i think it does,
    take a look at the 2nd site on the RF Parameters. in the FM section the headline is "FM (with RDS) Operation", so it should have rds
    it looks very interesting at all. do you know something about the prices???
  5. #665
    Raw Wave RoyN's Avatar
    So Paulo, Brazil
    the key thing is: can someone obtain a reasonable quantity??? (something less than 100 units, upto 5units purchasing at a time or something for hobbyists)
    it is probably not very likely that they would sell eagerly to hobbyists at these quantities, but if they do then I guess we are on to yet aanother alternatrive...
    2005 Range Rover 4.4
  6. #666
    FLAC TheLlama's Avatar
    Jul 2004
    All over the world
    I had a dream last night. In this dream I was listening to the radio on my carpc. Of course, it was only a dream.
  7. #667
    Maximum Bitrate Frankino's Avatar
    Nov 2004
    Quote Originally Posted by TheLlama
    Peugeot 206 1.4 HDi
    Intel Mini-ITX Mainboard
    Celeron 1.2ghz
    256mb DDR-2 533
    80gig 3.5" SATA HDD
    Sb Live 5.1 w/ KXProject Drivers
    8" Lilliput TS LCD
    100% installed and working :D
  8. #668
    phc is offline
    Variable Bitrate phc's Avatar
    Aug 2003
    Dream no more?
    Order now for about 200 euro (delivered)
    A bit pricey and comes in from Germany, but for double the price, you can get this from the down under.
  9. #669
    FLAC ShawJohn's Avatar
    Aug 2004
    On the edge!
    So does Digital Radio Mondiale (DRM) work everywhere in Europe, or just Germany?
    Can DAB/DVB stations be received on a DRM radio?
  10. #670
    Jan 2005
    Hampshire, UK
    Having looked at the application programming interface (API) for the Digital World Traveller radio, it does not appear to provide any access to RDS or data functions. It is not clear from the product data sheet whether the radio actually supports RDS in FM (essential in a car IMO), but it does seem that their supplied app has some DRM data capability. Since the channel decoding seems to be done on the PC, it is presumably possible to access the data given an API.
    So, this looks like a possible solution, but needs more s/w support. It is expensive, but at least it's available.
    The WinRadio is really expensive (particularly for an FM-capable USB version), does not obviously support RDS and relies on the power of the PC (and the audio card) to do much of the demodulation. One would need to be sure that an EPIA motherboard would have the grunt necessary for this. Winradios seem to be aimed mainly at the amateur radio fraternity.
  1. CarPC Remote control of FM Radio / Amplifier within Blaupunkt HU
    By ProCos in forum General Hardware Discussion
    Last Post: 05-28-2011, 09:56 AM
  2. 1/2 din AM/FM radio ????
    By spectrrr in forum General Hardware Discussion
    Last Post: 10-08-2005, 07:45 AM
  3. HU Quality AM/FM RDS/RBDS Radio with Features
    By Seth in forum Hardware Development
    Last Post: 01-20-2005, 09:59 AM
  4. Custom AM/FM radio display?
    By ShinkunoNamida in forum General Hardware Discussion
    Last Post: 02-25-2003, 07:28 PM
  5. AM/FM radio
    Last Post: 05-15-2002, 08:40 PM
