Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: Help needed from EE gurus - 5 channel A/B switch
  1. #11
    Oct 2002
    perhaps easier to use relays- a single pole switch can control
    multiple relays to give you enough switchable contacts.
    Power the relays from the pc psu and when its off "the Mrs" can't possibly
    mis-switch the inputs
  2. #12
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    Quote Originally Posted by davesaudio2
    That is the way to go.
    Or you can get a Manual KVM switch box or data switch but they all tooooooo BIG
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
  3. #13
    Constant Bitrate BeaverWise's Avatar
    Oct 2004
    Germany
    If your serious about it check out this.
    RS-232 Controlled 4x1 Stereo Audio + Video Switcher
    http://www.controlanything.com/Merch...ct_Code=AVS4X1
    VIA MII 10000 - 512MB Ram - Dual 2.5" drives, Xenarc 700TSV, Panasonic CW-8132-B, Opus 150, Audigy 2 NX, PowerMate, IOADR1610 10 Relay card
  4. #14
    Variable Bitrate BiohazrD's Avatar
    Katy TX
    Quote Originally Posted by Dr. Jeff
    I will be using a pair of these coming off the HU:
    http://www.crutchfield.com/S-Bpx7Sma...e+level+output
    You can get one of those at Wal-Mart for $5. Never buy from Crutchfield.
    Quick! To the Popemobile!
  1. Capture GPS data at the flip of a switch
    By Mr. Inquisitive in forum GPS
    Last Post: 02-02-2005, 07:06 PM
  2. FP Feature Requests
    By frodobaggins in forum FrodoPlayer
    Last Post: 10-15-2004, 02:19 PM
  3. Help needed on switch install for Inverter
    By eazyrog in forum Power Supplies
    Last Post: 07-24-2004, 07:42 AM
  4. Need clairification on wiring on/off switch
    By syclone477 in forum Newbie
    Last Post: 03-23-2004, 05:59 PM
  5. Decoder with A/B switch or ATI TV OUT?
    By berniejr in forum General Hardware Discussion
    Last Post: 04-12-2002, 01:10 AM
