Results 1 to 10 of 14
Thread: Help needed from EE gurus - 5 channel A/B switch
    Jan 2005
    I am going to need to build (or find) a device that will allow me to choose which set of inputs my 5 channel amp will accept. What I am doing is retaining my stock head unit and adding the carputer's USB 5.1 soundcard to the mix. According to the stereo install shop doing some custom work for me, I cannot feed both into the amp at the same time. I have searched online for about 2 hours but either I am a moron (likely) and have not found it, or it doesn't exist. I have no EE skills.
    Could someone design a simple device (I'll pay whatever is needed ) which will allow this?
    Thanks!
    ADDENDUM EDIT:
    Reason I am doing this is to allow surround sound thru the rear spkrs. True, any radio with an AUX-IN will allow regular 2-channel control, but will not acccept the proper inputs from the carputer.
    Nic
    Nic is offline
    FLAC Nic's Avatar
    Oct 2003
    Melbourne, Australia
    is surround sound really nessicary? are you going to be watching plenty of movies?
    Signature: [==||========] 20% complete
    Maximum Bitrate kiltjim's Avatar
    Feb 2004
    PA, USA
    So, if I understand you correctly, you want to choose between a 4 channel source (you head unit) and a 6 channel source (your computer)? Are they both analog?
    If this is the case, you could easily use the same switch that I've been using to add a second aux-in to my HU.
    Use a 4017 chip (LED chaser) to drive a buncha transistors that are tied to the inputs, and the outputs.
    2000 Subaru OBS
    Dell P3 @ 900 Mhz
    7" Lilliput TS w/DigitalWW in-dash mount
    80GB External HD
    I am Zero Bitrate....
    Jan 2005
    Switch
    It's no so much for the full surround effect only, but since I am using the Audigy 2nx, and it has front, rear, and sub outs, I'd like to make use of that.
    Yes, they are all analog. The reason behind most of this is my wife... she wants no part of the carputer; she wants to be able to get in the truck and press the radio button to hear music right away. Also, until they get the FM card project working, I'd rather not have crappy FM music sound.
    May 2004
    NJ
    One issue though, the HU puts out speaker level signal, while the sound card puts out line level signal. You will need to find a way to work that out, there are AMPs that will accept both, but only one set active (connected) at a time. Sorry, can't be of much help but those are the issues, I hope there is an easy way, I am in the same boat.
    Jan 2005
    Line level output
    I will be using a pair of these coming off the HU:
    http://www.crutchfield.com/S-Bpx7Sma...e+level+output
    Maximum Bitrate mushin's Avatar
    Aug 2004
    SE Michigan
    Not a EE guru, but I can help. This is a much simpler problem then you might be imagining . The only thing really complicating it is that you have so many channels. If the grounds on each channel can be tied together (I think so, but you might want to double check) then you need a 6PDT switch (or several DPDT switches, but you probably don't want to have to flip several switches.) 6PDT switches are a bit unusual, but a quick google search found one here. You then tie the corresponding PC and HU channels to the switched terminals of the switch, and the outputs to the amp. Ground would be made one of the terminals, and redistributed to each channel after the switch. On the off chance that the grounds aren't common, you'd need a 10PDT, which might be a stretch for one switch.
    Alternatively, you *can* feed both HU and PC in at the same time. What you want for that is a mixer, and an extremely simple mixer circuit should do the job.
    Jan 2005
    I want to do the same thing, but what I have found but not sure of is if you put one set of RCA's and put them in the input of ur USB 5.1 soundcard ... I think it will poass through and out to your amp... i think this will work if it does not rely on the USB for power.. I am not sure
    Jun 2003
    Chicago
    Assuming you only want front/rear/sub why not use an Eq that has an auxilliary input like I do. It's a Clarion PEQ460, it's 1/2 din, has two 2 channel inputs and and has front, rear and sub ouputs. It also volume control, fader,low/mid/high control, crossover frequency control as well as sub volume control. It has a switch on the front to switch between main and auxillary inputs. If you turn it to aux and back to main every time you use the vehicle the wife will never know the difference.
    Here is a link: http://www.autovibes.com/clarpeqineq.html
    I got mine for $40 brand new on ebay.
    Jan 2005
    that is nice but i am looking for a swicth for each source away from the EQ, and I do not want to put it in the dash i want to keep the dash as stealth as possible, i want everything hidden to prevent theft, I want the HU to control the volume too
  1. Capture GPS data at the flip of a switch
    By Mr. Inquisitive in forum GPS
    Last Post: 02-02-2005, 07:06 PM
  2. FP Feature Requests
    By frodobaggins in forum FrodoPlayer
    Last Post: 10-15-2004, 02:19 PM
  3. Help needed on switch install for Inverter
    By eazyrog in forum Power Supplies
    Last Post: 07-24-2004, 07:42 AM
  4. Need clairification on wiring on/off switch
    By syclone477 in forum Newbie
    Last Post: 03-23-2004, 05:59 PM
  5. Decoder with A/B switch or ATI TV OUT?
    By berniejr in forum General Hardware Discussion
    Last Post: 04-12-2002, 01:10 AM
