Page 12 of 25 FirstFirst ... 2345678910111213141516171819202122 ... LastLast
Results 111 to 120 of 241
Thread: XM on Carputer THE GUIDE
  1. #111
    Raw Wave BoyNextDoor's Avatar
    Aug 2004
    Walden, NY
    Quote Originally Posted by Viscouse
    I need 3. I have a commander that is already wired intot he car. I will not change any power (and I wouldn't carry power in the same cabel anyway, just like your cable), just signal. There are 3 signal wires.
    Question still stands.
    ok, but i'd be still worried of interference. if you get a good shielded phonecable, i can't see why not...
  2. #112
    MySQL Error jcdillin's Avatar
    May 2003
    Miami, FL
    It has to be shielded or you will get problems with the list loading and channel changing, my very first cable was not shielded and I had problems. Since then i've gone shielded and everything is fine and dandy
    肚子笑痛了
    S60 Install
  3. #113
    Jul 2005
    Sedona, AZ
    I built a cable to the specs of the I-hacked/this forum directions, and it doesn't work. All of the pins should be right, and I dont need power, since it is already installed in my car. I do not really understand, it doens't do anything like it is supposed to. I start of the software, and I get the same response as if i didn't have anythign plugged in, really annoying. It is shielded also, because It was not at first, and then I made it to be. Any ideas? Are those directions not quite accurate, or is there anywhere besides www.hybrid-mobile.com that I can buy a premade cable?
  4. #114
    Variable Bitrate Viscouse's Avatar
    Jul 2005
    Motor City
    Thanks guys! I'll give it a whirl.
    You know you want to...Worklog
    Enjoying v1.0 since it's operational. Aaaawww yeah.
    Specs: Opus120; Epia M10k; 700IDT; GlobalSat BR-355; iGuidance 2.1 & IGMod; XM; Custom case.
    Witty one-liners currently quoted by (0001) mp3car.com forum member sigs.
  5. #115
    Variable Bitrate looneeii's Avatar
    Feb 2005
    Gatineau, QC, Canada
    Dumb question but you have to subscruibe to XM first of course? Cuz in Canada don't think we can yet...
    99 Grand Prix Grand Tigress
    HW
    Liliput 8in TS
    845GVD MITX w/ 2.4 Mobile P4M (478 MB)
    60GB 2.5" HDD
    MS MN-710 WifiG
    BT Deluo lite GPS
    IrDa PS/2 Keyboard
    SW:
    Win XP SP2
    RR
    IGuidance 4.0
    Zots day skin
    Proscan 4.0
    (100% Complete!)
  6. #116
    Aug 2004
    Walden, NY
    Quote Originally Posted by looneeii
    yes, w/o a subscription the xm unit ain't working...
  7. #117
    Apr 2005
    I want to verify if the pin diagram is looking at the "front" of both the db9 and the 8-pin (not the side the wires hook to). I read in an earlier post it was looking at the front, but the db9 I bought has pins number on the front opposite of what they are shown on the original post.
    Car-mada-puter Epia MII12000, 40gig HD, 512mb ram, Morex 3688 case, M1-atx and XP Pro.
  8. #118
    May 2003
    Miami, FL
    use the pin numbers printed next to the pins for reference. That picture is probably looking at the male version of the connector.
    And yes, that is looking at the 8pin connector
    肚子笑痛了
    S60 Install
  9. #119
    Nov 2004
    St Louis
    Quote Originally Posted by BoyNextDoor
    That's not exactly true. I have an XMD on my development system that has no subscription. It gets channels 1 & 247. Good enough for most testing.
  10. #120
    Maximum Bitrate MoFo's Avatar
    May 2004
    TX
    hey guys,I'm trying to find out where i should get power for my xm direct .i'm not much of an electrician. Should i get it from the inverter i have or maybe the amps that are already back there? heres a picture:
  1. carputer install: I dare you...
    By Cat Monkey in forum General MP3Car Discussion
    Last Post: 01-27-2005, 06:34 PM
  2. XM Direct digital adapter or XM PC cable with SkyFi2???
    By LATEOTT in forum Hardware Development
    Last Post: 01-19-2005, 03:18 PM
  3. Using an XM direct as an XMPCR
    By dacndar in forum General Hardware Discussion
    Last Post: 10-17-2004, 02:21 AM
  4. XM Sirrius for carputer?
    By withoutcomp1 in forum Newbie
    Last Post: 05-01-2004, 10:04 PM
  5. XM Sat Radio for your carputer
    By jzgt in forum General Hardware Discussion
    Last Post: 12-20-2003, 01:51 AM
