Page 13 of 25 FirstFirst ... 34567891011121314151617181920212223 ... LastLast
Results 121 to 130 of 241
Thread: XM on Carputer THE GUIDE
  1. #121
    MySQL Error jcdillin's Avatar
    May 2003
    Miami, FL
    yeah you can power it from either the amp or the inverter
    肚子笑痛了
    S60 Install
  2. #122
    Maximum Bitrate MoFo's Avatar
    May 2004
    TX
    when i checked the inverter it was 13.9v. The molex in a desktop is 12.0V. Will it be ok to have a power source that is 2 extra volts?
    Thank you very much jcdillin
  3. #123
    May 2003
    Miami, FL
    yes, the xmdirect has a good regulator in it, I have ran mine from 15v with no issues at all.
    肚子笑痛了
    S60 Install
  4. #124
    Variable Bitrate Viscouse's Avatar
    Jul 2005
    Motor City
    I'd check the specs & see what the unit is rated at. I agree it has a good regulator in it, but safer to check just in case. The specs should have "input Voltage" or something like that.
    You know you want to...Worklog
    Enjoying v1.0 since it's operational. Aaaawww yeah.
    Specs: Opus120; Epia M10k; 700IDT; GlobalSat BR-355; iGuidance 2.1 & IGMod; XM; Custom case.
    Witty one-liners currently quoted by (0001) mp3car.com forum member sigs.
  5. #125
    May 2003
    Miami, FL
    from
    http://www.terk.com/xmdirect/
    Smart Digital Adapter Specifications*
    Technical Information:
    Frequency:2320 to 2332.5 MHz
    Bandwidth:12.5 MHz
    Working Voltage Range: 7.5V min to 16V max
    Active Current Consumption: 70mA min to 100mA max
    Idle Current Consumption:5mA
    XM Approved: Certified
    肚子笑痛了
    S60 Install
  6. #126
    Apr 2005
    Should the xmdirect 12volt be connected to a "always on" or ACC?
    Car-mada-puter Epia MII12000, 40gig HD, 512mb ram, Morex 3688 case, M1-atx and XP Pro.
  7. #127
    May 2003
    Miami, FL
    doesnt really matter, only problem with connecting it to always-on is that you run the risk of draining your battery.
    肚子笑痛了
    S60 Install
  8. #128
    Apr 2005
    Thanks, I didn't know if there was any retained memory issue or not.
  9. #129
    May 2003
    Miami, FL
    Well I have been running mine on switched power for close to year now without any issues at all.
    肚子笑痛了
    S60 Install
  10. #130
    Newbie calico's Avatar
    Sep 2005
    stupid questions,
    does this XM works in Indonesia region ?
    how many channel ?
    rud
  1. carputer install: I dare you...
    By Cat Monkey in forum General MP3Car Discussion
    Last Post: 01-27-2005, 06:34 PM
  2. XM Direct digital adapter or XM PC cable with SkyFi2???
    By LATEOTT in forum Hardware Development
    Last Post: 01-19-2005, 03:18 PM
  3. Using an XM direct as an XMPCR
    By dacndar in forum General Hardware Discussion
    Last Post: 10-17-2004, 02:21 AM
  4. XM Sirrius for carputer?
    By withoutcomp1 in forum Newbie
    Last Post: 05-01-2004, 10:04 PM
  5. XM Sat Radio for your carputer
    By jzgt in forum General Hardware Discussion
    Last Post: 12-20-2003, 01:51 AM
