Page 19 of 25 FirstFirst ... 910111213141516171819202122232425 LastLast
Results 181 to 190 of 241
Thread: XM on Carputer THE GUIDE
  1. #181
    Variable Bitrate kamikaze2112's Avatar
    Feb 2005
    Barrie Ontario
    Quote Originally Posted by djurchicprelude
    are both of those lil wires positive? or does the yellow one go to a 12v and the black one to a ground?
    Yellow to 12v, Black to Ground
  2. #182
    Newbie shaggy_5420's Avatar
    Feb 2006
    Near St. Louis, MO
    Can anyone help me find a link to TouchXM? all of the links here on the forums seem to be dead ends. I have tried over and over to get Frodoplayer to work but I always get an error before the program starts stating that
    "MSCOMCTL.OCX or one of its dependencies is not correctly registered...blah blah....."
    I just wanted to see what I have wrong and I really would like to try TouchXM
  3. #183
    FLAC chut's Avatar
    Jul 2003
    San Antonio, TX. USA
    Have you tried registering the file manually? regsvr32 (filename)will do it for you if the file exists. You may have to type in the entire path to the file. I have a copy of another XM program if you send me an email address that can handle about two mb, Ill send it to you. I dont have a copy of touch XM. Which XM device are you using?
    Peter
    Quote Originally Posted by shaggy_5420
    Stop Buying New Music CD's.
    Hit The RIAA where it lives.
    Indash Motorized 7", Epia Nehimiah, 512 MB, 80 GB, DVD, Wireless G, XP Pro, XM PCR, Kenwwod 5 Channel 1200 Watt Amp.
  4. #184
    Feb 2006
    Near St. Louis, MO
    I am using the TERK XMD1000 and a home made cable. I actually got the unit functioning, and I am using a variety of different programs for access and control, S.R.C., and I just started using one called Mobile Impact (MI) but I am up to try whatever. I want to get frodo player to work, I can get it to open now but unfortunately, I still cant seem to get it to talk with the receiver. I like the look of Frodo, and I would Really like to find TouchXM, but like I said I would like to try a few programs see what I am up against for the total system.
  5. #185
    Variable Bitrate wallaceacura's Avatar
    May 2005
    SE Wisconsin
    Thank You For This Thread!!!!!!
    This thread is a lifesaver!! I just picked up a Terk XMD module on eBay for $31 with a $30 rebate and the parts to make a cable for about $12. 30 minutes later and I have XM in RR!
    I figured this would take me a few tries to get the cable right, but managed to get it right on the first shot. I opted not to go the solder route and instead went with the crimp connectors from rat shack (276-1428). Crimping is much easier than soldering when working with those thin wires IMO. Not sure if it helps, but I used a shielded hood as well (276-1513).
    One thing I discovered is half of my cable matched the color pinout and the other half was a mirror image. The cable must cross the signals from one end to the other. At any rate, the other half of the cable worked out to be:
    1: Red
    2: Brown
    3: Green
    4: Yellow
    5: Orange
    6: Black
    7: Purple
    8: Blue
    For what it's worth...
    Biostar M7NCG 400 ver 7.2 AMD Mobile Athlon 1.1GHz (@ 1GHz), Kingston PC2700 512mb WD 80gig HD Custom Case Opus 150W PS Lilliput 7" TS D-Link DBT-120 BT D-Link DWL-G122 WiFi Holux GR-231 GPS nLited XP Pro iGuidance RoadRunner frontend
  6. #186
    May 2005
    SE Wisconsin
    If anyone is interested in a cable, I have an extra one made up. $20 shipped.
  7. #187
    Variable Bitrate DaveB's Avatar
    Mar 2004
    The Mini Din 8 connector -- is that the same connector that is on the end of PS/2 style mouse cable? If not, has anyone found the proper connector at Best Buy or radio shack? I've been looking and haven't seen anything that looked correct.
    8" Lilli TS
    MB896F Mini-ITX MB
    2GHZ Dothan 533MHz FSB CPU
    1GB SDRAM DDR2 533
    Seagate 300GB SATA150 HD
    ENGENIUS WiFi MINI-PCI CARD 802.11A B 400MW OUT
    Pioneer Slot Load SLIM DVDRW
    Bluetooth V2 USB 2 Dongle
    3COM BKP Cam
  8. #188
    Maximum Bitrate fixerofallthing's Avatar
    May 2005
    Lawrenceville GA
    Apple serial printer cable at Fry's
    The Car 2005 Scion xB
    The Truck 2004 GMC Canyon
  9. #189
    Mar 2004
    We don't have a Frys in Minnesota. I may be able to locate an apple serial printer cable though. I don't think Best Buy or rat shack has them but Compusa might. I'll have to do some more looking. I was hoping to find stuff locally today so that I could get to work on it.
    8" Lilli TS
    MB896F Mini-ITX MB
    1GB SDRAM DDR2 533
    3COM BKP Cam
  10. #190
    MySQL Error jcdillin's Avatar
    May 2003
    Miami, FL
    yeah it has to be a mac printer cable, no store has the din connector, besides digikey or mouser
    肚子笑痛了
    S60 Install
  1. carputer install: I dare you...
    By Cat Monkey in forum General MP3Car Discussion
    Last Post: 01-27-2005, 05:34 PM
  2. XM Direct digital adapter or XM PC cable with SkyFi2???
    By LATEOTT in forum Hardware Development
    Last Post: 01-19-2005, 02:18 PM
  3. Using an XM direct as an XMPCR
    By dacndar in forum General Hardware Discussion
    Last Post: 10-17-2004, 01:21 AM
  4. XM Sirrius for carputer?
    By withoutcomp1 in forum Newbie
    Last Post: 05-01-2004, 09:04 PM
  5. XM Sat Radio for your carputer
    By jzgt in forum General Hardware Discussion
    Last Post: 12-20-2003, 12:51 AM
