Thanks guys. I found an
Apple PC store and bought the serial printer cable.
I bought a Terk XMD1000 and installed it and I have everything working under Road Runner. Its pretty slick!
The only problem I have now is that the Terk XM
radio introduced noise. I'm getting a rythmic noise that cycles up and down. Its kind of a white noise with an underlying tone of some kind. This is with the engine turned off. Its not alternator noise.
I assume serial cable is shielded and I did solder the braided ground wire to the outside of the DB9 connector. So I have a good ground on the cable. I also have a shielded shroud around the DB9. The two
power wires, which are powered from my M2-ATX power supply, are plain 18 guage wires (no shielding)
The RCA cable I bought looks like a pretty cheap cable. Its a 6 foot Y adapter cable that goes from two RCA females to the 1/8 inch jack -- which plugs into the line-in on my PC. I'm guessing I may need to replace it with a shielded cable.
I have no idea whats causing the noise in the system, though. Has anyone else run into this problem. You guys agree that it may be the RCA cable?
