you can't plug the XMD into the computer while it's running, most systems shut down because of the very high initial draw of the XMD. It always has to be plugged in before you turn it on. Especially if you have a M1 or a M2ATX
anyone have any idea on why when i plug in my XMD unit my computer shuts off? If i just have the cable plugged in the ocmputer funs fine but as soon as i plug it into the XMD unit it shuts off...
i double checked all the connections with a multimeter... not sure whats goin on
肚子笑痛了
S60 Install
ive tried that too. i tried it first. but if i have the XMD unit plugged in and try to start up the computer i see the fan on the motherboard move enough to make about 1/7th of a rotation then it wont do anything until i unplug the unit.
did you purchase or make the cable? Sounds like the power lines are backwards, have you tried reversing them just to see if it works?
肚子笑痛了
S60 Install
no, i didnt try that. i double checked the pins with a multimeter to amke sure they all matched up with the diagram... I also have not tried plugging it in without hooking up the power wires. i guess if it works then it would prove its the power wires and not anything in the serial connection i soldered.
Well any shorts in the serial connection will not prevent the machine from turning on, it will just keep the connection from working. But if you made the cable yourself just double check the pins, it's very easy to get them backwards.
肚子笑痛了
S60 Install
ok they were backwards, but not int he cable i made. i had the pins in the molex connector backwards.
but anyway now im getting this when i try to listen
Not Subscribed to Premium Channel | Could Not Change Channel
but then it also shows this.
Signal Status: Great
Antenna Status: Connected
Sat1 Demod: No
Sat2 Demod: No
Ter Demod: Yes
Sat1 Demod: No
Sat2 Demod: No
Ter Demod: Yes
Sat1 BER: 5440 (100.0%)
Sat2 BER: 5440 (100.0%)
TER BER: 0 (.0%)
Sat1 C/N: 3.0
Sat2 C/N: 3.2
any ideas?
i know i have the radio activated... im not getting any sound... not even the preview channel
oh and im using mobile impact if that matters
Well what you need to do is be sure that you have the correct line selected in mobile impact setup
also make sure that you have it turned up to about 1/4 to 1/2
also now you have the unit powered up you need to go to the XM site and resend the activation, if you don't it'll never activate and just give you issues. just send the activation and let the radio sit on for about 10 minutes, that should be good enough
also try closing mobile impact and muting the line-in and then opening the program
肚子笑痛了
S60 Install
i got it to work... you were right about the sound not coming in through the line in.
i plugged the xm unit right into my amps and i get sound. but it wont pick it up through the line in even if i try muting it firstor messing with volue or anything...
oh well it works though
