Page 24 of 25 FirstFirst ... 141516171819202122232425 LastLast
Results 231 to 240 of 241
Thread: XM on Carputer THE GUIDE
  1. #231
    Jun 2006
    Richmond VA
    Quote Originally Posted by midiwall View Post
    It's not about stealing the article per se', it's about directly linking to the images. That costs i-hacked bandwidth dollars.
    Do you have a link to the i-hacked article? I can host the images... Someone will then need to find the original poster and have them update the main page.
    Yes, I understand the bandwith stealing.. but earlier the same images (bandwith stealing) were displayed on i-hacked website as well. Seems that only one is up now, but it is not necessary. They are located here:
    http://www.i-hacked.com/content/view/56/90/
  2. #232
    Jun 2006
    Richmond VA
    Images are attached.
  3. #233
    Variable Bitrate 3g Jester's Avatar
    Nov 2005
    man i would love to see this with sirius
  4. #234
    May 2006
    Seattleish, WA
    Quote Originally Posted by zzzBrett View Post
    Okay... These are now posted up as:
    http://www.midiwall.com/mp3com/41001_xmcable.gif
    http://www.midiwall.com/mp3com/41001_pinout.jpg
    http://www.midiwall.com/mp3com/41001_xm-serial.jpg
    They'll be there for ever as far as I'm concerned.
    :: Mark
  5. #235
    Jun 2006
    Richmond VA
    Now that my car computer is up and running, i'm starting on the XM side:
    I am using my M10000's audio output as 5.1 audio, so I don't have a "line in" per say. What other options do I have to input the audio from this XM Direct universal tuner?
    Also one more question - where can I find the 8 pin mini din plug? Please link me if radioshack or any other retail stores have it -- if not even an online store would be great.
    Thanks,
    Brett
  6. #236
    Aug 2007
    Remote power pin?
    From reading through this and other threads, sounds like powering the XM unit from the ACC line is preferable to the "always on" BATT line. Any chance that one of the two power pins (6 & 7) are a "remote" power line that lets you power the unit from the BATT line?
    I'm planning to run the unit from the ACC line anyway (already fabricated the cable), but thought I would still ask.
  7. #237
    May 2006
    Seattleish, WA
    Quote Originally Posted by jim8675309 View Post
    "Remote" with the intent being, that the unit wouldn't power up unless the serial port went active or ???
    There's no reason to run it from the BATT line... it'll just draw power. Given that you'll have other things powering up after you start the car (head unit, PC, amps, etc) then the XM box will have plenty of time to init before you'd expect to hear it.
    :: Mark
  8. #238
    Aug 2007
    Just like an amp. The "working" power comes from the BATT line, but the unit is only active if there is power on the "remote" line, regardless of whether there is any signal on the input lines (serial port in the XM case).
    For some context, I was trying to minimize the number of loads on the +12V from the DC-DC power supply, hoping to rely on the BATT line as the working power, using a "remote" power-on signal from the +12V (or the "remote" out of the DC-DC). I later realized that I could just hook it up to the IGNITION line that goes into the DC-DC, so I get the same net results anyway. Which is why I posed the question as more of an informational one.
  9. #239
    _
    Mar 2004
    Little Elm, Texas
    Quote Originally Posted by msb5150 View Post
    I really like your guide, simple and picturesque, the only thing I'd caution you about is linking pics from other sites, they could change and ruin the guide, or, if this thing were very popular, they might not take to kindly to you stealing their bandwidth and change them to something not so nice and pics of an xm direct cable.
    hrmmm....*scratches head*....
    Jan Bennett
  10. #240
    Jan 2007
    what if i have a laptop and only usb port available....thx for any help
  1. carputer install: I dare you...
    By Cat Monkey in forum General MP3Car Discussion
    Last Post: 01-27-2005, 05:34 PM
  2. XM Direct digital adapter or XM PC cable with SkyFi2???
    By LATEOTT in forum Hardware Development
    Last Post: 01-19-2005, 02:18 PM
  3. Using an XM direct as an XMPCR
    By dacndar in forum General Hardware Discussion
    Last Post: 10-17-2004, 01:21 AM
  4. XM Sirrius for carputer?
    By withoutcomp1 in forum Newbie
    Last Post: 05-01-2004, 09:04 PM
  5. XM Sat Radio for your carputer
    By jzgt in forum General Hardware Discussion
    Last Post: 12-20-2003, 12:51 AM
