Page 8 of 25 FirstFirst 123456789101112131415161718 ... LastLast
Results 71 to 80 of 241
Thread: XM on Carputer THE GUIDE
  1. #71
    Raw Wave tbird2340's Avatar
    Oct 2003
    Poland, OH
    For the 12V power, can I just tap into a switched power source in my truck or do I have to power it off my carputer...
    Current Vehicle: 2007 Dodge Nitro
    Second Vehicle: Sold it :( 2005 Dodge Ram 1500 Quad Cab
    First Vehicle: 2003 Ford Ranger
  2. #72
    Oct 2003
    Poland, OH
    Stupid question #2: If I'm going to be plugging this into my Epia board do I still need to get the female db9 connector & hood or do I just get the V1 riser connector?
    Stupid question #3: Where can I get the 8 pin mini-diin cable? Do I get it and just snip the other end off?
  3. #73
    Oct 2003
    Poland, OH
    Just ordered all the goods.
    XMD1000 - $41.88 shipped from thezeb.com
    DB9M to IDC10 Serial to connect to Epia M10000 ($1.25) and Mini Din8 M-M 6ft. cable ($3.99) - $11.75 shipped
    = $53.63 total!
  4. #74
    MySQL Error jcdillin's Avatar
    May 2003
    Miami, FL
    Quote Originally Posted by tbird2340
    I power mine from the carputer, just for ease of it
    I think the XMD has a good enough power supply in it to power it from the cars electrical system. But since it has a serial connection to my computer I didnt want to risk it
    肚子笑痛了
    S60 Install
  5. #75
    May 2003
    Miami, FL
    = $53.63 total!
    dont forget if your going to use that serial header you will need a mating db9 connector and hood
    肚子笑痛了
    S60 Install
  6. #76
    Oct 2003
    Poland, OH
    Quote Originally Posted by jcdillin
    I was just going to snip off the DB9 off of a modem cable and solder the wires from it and the 8 pin mini-din.
    That would work wouldn't it?
  7. #77
    May 2003
    Miami, FL
    it would work, but it's going to be messy and a pita, just go to radio shack and spend the $2 for a proper connector
    that way you can just snip one end of the din off and solder the wires directly to the DB9 and to whatever your going to use for a power connector
    肚子笑痛了
    S60 Install
  8. #78
    Oct 2003
    Poland, OH
    I just find it a lot harder to solder directly to the DB9 compared to soldering two wires together. Why do you say it would be messy and a pita? Just because the wires are so thin?
  9. #79
    May 2003
    Miami, FL
    because the wires are thin, and then you end up with a cable that is connected in the middle instead of one end.
    But if you feel more comfortable soldering the wires together then go for it. It should still work fine
    肚子笑痛了
    S60 Install
  10. #80
    Oct 2003
    Poland, OH
    Yea, thin wires do suck when trying to solder them. When I tried making my home brew IR receiver I had a heck of a time with the wires on the DB9.. Maybe I'll try again.
  1. carputer install: I dare you...
    By Cat Monkey in forum General MP3Car Discussion
    Last Post: 01-27-2005, 06:34 PM
  2. XM Direct digital adapter or XM PC cable with SkyFi2???
    By LATEOTT in forum Hardware Development
    Last Post: 01-19-2005, 03:18 PM
  3. Using an XM direct as an XMPCR
    By dacndar in forum General Hardware Discussion
    Last Post: 10-17-2004, 02:21 AM
  4. XM Sirrius for carputer?
    By withoutcomp1 in forum Newbie
    Last Post: 05-01-2004, 10:04 PM
  5. XM Sat Radio for your carputer
    By jzgt in forum General Hardware Discussion
    Last Post: 12-20-2003, 01:51 AM
