Results 1 to 8 of 8
Thread: Wiring help, possibly a relay?
    Newbie Ninety8NeonACR's Avatar
    Feb 2002
    WI
    What I am looking for is a simple way to open a circuit when power is supplied from a lead. This really isn't carputer related but I know you guys are electronics gurus. I need this to get my LED taillights I put on my motorcycle working correctly.
    Chris
    Car=Dodge Neon ACR.
    PC=Cappuccino GX1 Mini-Book - 800MHz, 256MB ,5GB, CD, XP payed $230
    Screen=8" Lilliput XGA T/S payed $360
    ITPS payed $46
    DVD Drive payed $43
    Ebay GPS Mouse + Software payed $52
    MySQL Error Scouse Monkey's Avatar
    Mar 2004
    Bristol
    yup use a relay. there is a pin guide in this section: http://www.mp3car.com/vbulletin/hardware-development/
    that will help you. Just make sure you get a relay that can take the power - brake lights are quite meaty but you only got one.
    Mar 2004
    Here is another good site the12volt.com
    Newbie dasbell's Avatar
    Jan 2005
    Orlando, FL
    Source for Relays
    You can check out All Electronics ( use ) to find whatever relay you end up needing. They are pretty cheap.
    Mar 2004
    Bristol
    Quote Originally Posted by Coeus
    yeah good site. heard a few people mention it
    Feb 2002
    WI
    Help me see if I am correct on how to wire a bosch 5 pin relay with this picture. If the circuit I want to open was hooked up to pin 30 and pin 87a and the wire with current that I want to open said circuit was hooked up to pins 85 or 86 would it work for what I need it to do? It appears to me it would but I switched majors after my first couple of EE classes.
    Chris
    Car=Dodge Neon ACR.
    ITPS payed $46
    DVD Drive payed $43
    Mar 2004
    Bristol
    my god, where did that pi come from???
    Feb 2002
    WI
    Car=Dodge Neon ACR.
    ITPS payed $46
    DVD Drive payed $43
  1. Electronics Question - Parallel Relay
    By blazinlow in forum General Hardware Discussion
    Last Post: 11-07-2004, 01:39 PM
  2. relay, inverter, fuse problems
    By cheesyhoward in forum General Hardware Discussion
    Last Post: 06-22-2004, 04:05 PM
  3. Queston conerning stinger 200 amp relay
    By vash in forum General Hardware Discussion
    Last Post: 05-25-2004, 11:15 AM
  4. Will someone help me program my relay control module
    By cproaudio in forum Software & Software Development
    Last Post: 09-04-2002, 05:50 AM
  5. Specific wiring schematic 4 Optrex DMC40457?
    By sooty in forum LCD/Display
    Last Post: 07-17-2001, 03:11 AM
