Results 1 to 7 of 7
Thread: anyone know how to interface this with a laptop. i dont have a touchscreen :-(
    Constant Bitrate minghi's Avatar
    May 2004
    Phoenixville, PA
    Nice find. Lets hope some people find out how to get it going.
    Maximum Bitrate mushin's Avatar
    Aug 2004
    SE Michigan
    It's probably PS/2, so if you wire it up to a PS/2 port, it'd work. However, without the pinouts, figuring it out could be quite a pain. You're best bet is to see if you can find it somewhere.
    May 2004
    Phoenixville, PA
    it would be very helpful for people living in the stone age (no touchscreen) . i have a lilliput with RCA input only, trying my best not to spend any more $$$$$
    best place to mount it would be on the steering wheel itself. what do ya think?
    Oct 2004
    NY
    The easy way to do what you want is to buy one of those pre-configured mouses that you hold in your hand trigger finger style & this tiny trackball is mounted on top of it designed to be rolled with your thumb. I've seen them all over so you should be able to find it, disect it & mount the trackball wherever, then mount your mouse click buttons (close by or remotely). this will give you what you want, all configured & wired to usb, drivers & all included, cost -$20-30 tops. I've used them, but they aren't super high quality & if you want buttery smooth, these are not quite, but not bad at all either.
    Yea I have used those finger type track balls a few times. They arn't bad but arn't great for how much they cost.
    Constant Bitrate cbergeron's Avatar
    You might want to look at using a steering column stalk (like this one). They're pretty affordable and they can work with most carputers.
    Hope this helps!
    -CB
    DashPC - The Linux Car (since 1999).
    Dash LCD, Via Epia, GPS, XM, OBDII, DSSC Shutdown Controller.
    As seen in the book Geek My Ride
  1. Remote laptop startup
    By ambush in forum Laptops, Netbooks, Tablets, UMPCs, etc.
    Last Post: 11-24-2008, 02:28 AM
  2. WTT: Looking For A 7" Touchscreen
    By theluckyducky in forum Classified Archive
    Last Post: 12-05-2004, 05:27 PM
  3. Laptop and Inverter?
    By ecaandrew in forum Power Supplies
    Last Post: 10-21-2004, 07:46 AM
  4. Replies: 4
    Last Post: 10-13-2004, 09:17 AM
  5. FS: Fujitsu subnotebook (B2131) small laptop with touchscreen
    By NordicNINE in forum Classified Archive
    Last Post: 09-25-2004, 10:34 PM
