Results 1 to 10 of 15
Thread: climate control with carputer
    Newbie mac2k6's Avatar
    Feb 2005
    does anyone know how to control the climate inside the car with the carputer what hardware and software would i have to use. links would help and instructions. thanx
    My Village Called 0l33l's Avatar
    Jul 2004
    Berkeley, CA
    I'd love to know to. It would help if you mentioned what car you had, etc...
    Maximum Bitrate Vchat20's Avatar
    Jan 2005
    Warren, Ohio, USA
    i just wonder what happened to that 4-ish page thread here that was full of talk about hvac<->comp interconnectivity. if it was still available i was gonna link him to it.
    nvm. found it. apparently the forum was set to only sow posts from the last day. look here for more info on computer controlled heat & A/C.
    Newbie Redeyez's Avatar
    Oct 2004
    San Antonio
    could you just use a usb servo controller to push the button/flip the switch? you could also use that to control windows and stuff.
    http://www.pololu.com/products/pololu/0390/
    Jan 2005
    Warren, Ohio, USA
    if its all electronic you could probably just get yourself a relay board (maybe more depending on your application) and wire the relays to thwatever switches/buttons youve got. the reason why the servo controller is needed is for the manual knobs and sliders for temperature and vent control.
    Feb 2005
    Quote Originally Posted by 0l33l
    it's a '04 vw golf gti with options like heated seats, i found a relay board for the windows, sunroof, hatch, and gas release http://www.dashwerks.com/dw_pvic.php but i'm not sure what has to be done for the temp controls since they're knobs.
    Variable Bitrate Sh0cker's Avatar
    Aug 2003
    LI, NY
    Quote Originally Posted by mac2k6
    it might appear the if you see knobs that means its all manual but yet in your case heater box and everything else is controlled via servos so you can easily wire it up to the parallel relay
    it can be done
    Danny.
    "If today was perfect, there would be no need for tomorrow."
    My Car Project® ‹== !10.4" Allbrite, touchscreen, epia, 150opus, gps, wireless, sony remote [old] 128x64 Crystalfontz +double din [new]
    Oct 2003
    Chicago, IL
    check out my site
    http://www.smokinmhz.net/
    Maximum Bitrate nFiniteTuning's Avatar
    Tijeras, NM
    Quote Originally Posted by Dexter
    check out my site
    Am I under the right impression that you got a control modual that will control the manual HVAC Controls? Like The buttons and temp and fan speeds?
    1987 Pontiac Fiero GT
    XPCarputer Coming Soon
    [IIIIIII---] 70% Complete
    XPC Model SN41G2V2
    AMD AthlonXP 1800+
    2× Mushkin 256MB DDR
    Pioneer DVDRW
    80GB 7200RPM UltraATA HD
    Windows XP MC2005
    XM Satellite Radio
    •ñFïnïtε Τחטіתģ•
    Oct 2003
    Chicago, IL
    In my car the venting and temperature selection is manually controlled by knobs. I needed to interface stepper motors to those. I use a parallel port controller board for that.
    For user info/keypad input, i am using a Crystalfontz 633.
    to control A/C, Defroster and Fresh/Recirc air, i am using the 3 of the 4 fan controlling outputs of the 633 to drive some logic chips to control the cars fan, and 3 of the GPIO to control relays for A/C, Defroster and Fresh/Recirc buttons.
    The software is being written in C#. I am still working on this but i am very close to being done. Ive been working on it for almost a year now.
  1. recommend a remote control for carputer
    By fallnangel in forum Input Devices
    Last Post: 01-16-2005, 09:51 PM
  2. carputer to control other lcd screens
    By NYCdesignkid in forum General Hardware Discussion
    Last Post: 11-23-2004, 03:34 PM
  3. Replies: 22
    Last Post: 06-23-2004, 03:40 PM
  4. How about using LiteStep for CarPuter Control?
    By JanneZ in forum Software & Software Development
    Last Post: 05-15-2004, 07:32 AM
  5. Using cd changer controls to control carputer
    By videodok in forum General Hardware Discussion
    Last Post: 09-29-2003, 03:28 AM
