Page 2 of 10 FirstFirst 12345678910 LastLast
Results 11 to 20 of 92
Thread: OEM GPS Modules.
  1. #11
    Jan 2003
    Ruston, LA
    Quote Originally Posted by camsgs3
    Im a little confuse here, From the pic I see, how would this mount in the case? Can I mount it some where in the trunk/anywhere, Does a M10K have an "internal" serial port? and how are you getting 3.3v in the car?
    thanks
    yes the m10k has an internal serial port
    3.3v comes off the ATX power supply
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
  2. #12
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    Quote Originally Posted by IntellaWorks
    The whole setup cost about 135.00 but really blows away a USB GPS mouse. These GPS mods were designed for system developers and advanced GPS applications.
    If your looking for a completely "embedded" CarPc then this would be the way to go, its great to hear from others that are using this hardware...
    I think the things I like about it most is that, I'm not using up a USB port I'm using up only 3.3v to power it up, it's smaller than any other GPS device (.75 * .5 * .5) L x W x H and its more capable than the normal USB devices you can buy.
    this may be a total noob post but, care to do a little write up on how you wired this up, etc...?
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
  3. #13
    Newbie Creoden's Avatar
    Jul 2004
    Ontario, Canada
    I was looking through the documentation and this looks like it is the proper wiring config for the unit.
    on another note, where can you buy these units?
    Creoden
  4. #14
    n00b 4 life mp3oplecarrier's Avatar
    Dec 2003
    Chatham, UK
    Quote Originally Posted by Spaghetti
    WAAS standard doesn't work over here apparently
    WAAS works by using a geostationary satelite to correct your position and give greater accuracy, the problem is that it is stationed above the United States!
    We will have our own version soon as the European Space Agency is going to position one above mainland europe. The standard for this is called EGNOS and will be compatible with WAAS although you may need a firmware update.
    Steve
    ....Yes, I know it has a stupid name, those crazy Japanese!
  5. #15
    Dec 2004
    Los Angeles Ca
    Quote Originally Posted by Creoden
    Creoden
    Awesome...looks simple enough to wire up...
    here is where you can buy one:
    http://getagps.com/products/gps/010-00240-02.htm
    M10k
    My Car Pc Install
    My Boat Pc worklog
  6. #16
    FLAC IntellaWorks's Avatar
    Jun 2004
    NH
    Ok, check this out. Using the internal serial interface on my MII I wired the GPS unit Data out to serial Datain and GPS unti Data in to Serial Data Out... As for the power, right next to the internal COM2 there is a 6 pin IRDA pin configuration, since Serial ports do not have power I could have used a 3.3v line from the ATX power supply but that would have required me to tap into a line...
    So what I did was use the 3.3v & ground from this IRDA connector, because I'll never be using that it worked out great.. plus even better was that it is less than an inch away from the internal com port...
    Progress [I will seriously never be done!]
    Via EPIA MII
    512MB RAM
    OEM GPS (embedded)
    nLite WinXP pro on
    1GB Extreme III CF card
    Carnetix 1260 startup/ DC-DC regulator
    Software: Still, re-Writing my existing front end in .Net
  7. #17
    Maximum Bitrate Bravellir's Avatar
    Dec 2003
    Porto, Portugal
    And what about the antenna? Does it came with the sensor or we have to buy that?
    Anybody has a pic of it?
    Ikea Case. Epia M10000.M1-ATX. 512 Mb. 2,5" 80 GB HDD. 7" Lilliput. BU-303 GPS. Sony Joystick.
    Status -->
    Lilliput Installed (not indash yet..)
    BraveCar 2.5
  8. #18
    Registered User mpattonm's Avatar
    May 2003
    Czech rep.
    Could you take a picture of your wiring, please?
  9. #19
    MySQL Error jcdillin's Avatar
    May 2003
    Miami, FL
    you have to purchase the antenna seperately, and you have to make sure that you are buying the unit that has the plug with pins instead of the ribbon cable. for ease of soldering wires.
    肚子笑痛了
    S60 Install
  10. #20
    May 2003
    Miami, FL
    Well mine should be here this week, I can't wait.
    肚子笑痛了
    S60 Install
  1. Getting Started with GPS
    By grepzen in forum The FAQ Emporium
    Last Post: 09-26-2006, 05:54 AM
  2. Newbie's guide
    By EBFoxbat in forum Newbie
    Last Post: 02-08-2005, 10:06 AM
  3. a new way of GPS
    By brownpage in forum GPS
    Last Post: 08-24-2004, 02:51 PM
  4. Window Tint's effect on GPS signal
    By MoFo in forum GPS
    Last Post: 07-19-2004, 05:08 PM
  5. USB DVD + Radio Tuner + OEM GPS
    By gguy in forum General Hardware Discussion
    Last Post: 02-13-2001, 11:43 AM
