Here is the route I plan to take: http://www.i-hacked.com/Car-Home/Car...Stars-GPS.html
While WAAS is US based, there is a system for us Europeans- DGPS differential GPS.
There are two ways of using DGPS..either software correction or straight from a device. Software correction takes a correction signal from a DGPS device, and combines it with a NMEA string to calculate the location. Hardware based correction can be achieved by Garmin.
Garmin do the
GPS 35 which is DGPS ready, i.e. plug a DGPS receiver box into the end of the GPS 35.
Such a DGPS receiver: http://www.outdoorgear.co.uk/eshop.a...001&affid=4171
http://www.effective-solutions.co.uk/dgps1.html - good info on DGPS
For GPS newbies, SA (Selective availibility has been turned off for a few years now) so DGPS is a bit of over kill for car satnav
ATVMS.com
Antenna
Wirring Harness from GPS MOD to system board
[Pictures of my actual setup comming soon]
Progress [I will seriously never be done!]
Via EPIA MII
512MB RAM
OEM GPS (embedded)
nLite WinXP pro on
1GB Extreme III CF card
Carnetix 1260 startup/ DC-DC regulator
Software: Still, re-Writing my existing front end in .Net
Yeah after I get my unit i'm going to post some pictures as well.
肚子笑痛了
S60 Install
I now hate you all, I was going to just go the gps usb mouse route like a lot of people do, but now I think I will have to get myself one of these and see what upgrades I can do to it...![]()
Yeah I have always wanted to go the OEM route, now I will have 2 sat antennas on my car. now I just need to add sirius and directv![]()
肚子笑痛了
S60 Install
well Looks like I will be placing an order for one of these things. I've already started work on a daughterboard for it I'm making so I can interface this thing with my aprs radio and compute via serial & USB
Cudos to everyone willing to go this route. I really think its a great mod and really small and so easy to use. I'll have pictures comming up soon, I just need to get my roomates cam and put em' on the web I'll try and post em' tonight.
Again if you guys are doing this and need to test to see if you actually got a signal, you can do 2 things:
1) use windows hyperterminal
2) use the delou gps tool I gave a link to in the begenning of this thread.
FOr those of you who nLited thier XP installs, you will probably have to download the delou tool becuse you most likely took out windows hyperterminal.
THe GPS tool is better than hyperterminal, because it actually reads the NMEA 1.83 data and puts it into a somewhat readable form, (it shows you how many sats its tracking, location, MPH (if any) and altitude from sea level)
Hyperterminal would just spew out whatever it sees comming from the COM port also it wont auto detect your gps like the diag tool will.
Via EPIA MII
512MB RAM
OEM GPS (embedded)
nLite WinXP pro on
yeah the gps tool is awesome, I have been using it for another project. I think we should start a new thread for OEM gps module installs.
肚子笑痛了
S60 Install
I'd definatly love to see a OEM gps install thread, it's importance can have a great value to our comminity.
For everyone that doesn't know these GPS mods are 1/5 the size of a standard USB/Serial GPS mouse.... Yet they are just as if not more capable than the USB gps mouse... ALSO the greatest values for you nlite poeple is that you do NOT need a driver !!!!!! just point your mapping software to whatever com port the OEM mod is on and it will get the NMEA data...
Via EPIA MII
512MB RAM
OEM GPS (embedded)
nLite WinXP pro on
