Page 9 of 10 FirstFirst 12345678910 LastLast
Results 81 to 90 of 92
Thread: OEM GPS Modules.
  1. #81
    Jan 2003
    Ruston, LA
    Registry fix for jumping mouse.
    Attached Files Attached Files
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
  2. #82
    Feb 2004
    NYC
    Quote Originally Posted by hklomann
    look what i got as 2 port usb2serial converter cable
    itīs not what i expected but i will give it a try
    i realy could not belive that it includes a 4port usb hub
    it was hard work to chop it
    Why do u need 2 serial?
    Also, would you still have the detection problem with windows when you convert rs232 to usb? The main reason why I switch my usb gps to serial gps is every time I got out of sleep, i had to unplug and replug my usb gps mouse in order for windows to understand that gps mouse is a gps mouse instead of a unknown gps device.
    If worst comes to worst, i may have to look for pci to serial to give me additional ports to make this works.
    I already used com1 for my touchscreen and com2 for my gps...
  3. #83
    Newbie hklomann's Avatar
    Nov 2003
    Germany NRW
    the usb 2 serial coverter works fine with the 3 volt cmos level serial signal from the ublox module and all navigation software listens on com/virtual com port for their input and i always have free/unused usb onboard conectors the other reason why i don`t attach direct to serial is cause my module shall be usb bus powered and the module might be placed internal or externaly i never had any recognition problems with gpsmodules on usb 2 serial or direct serial except of the well solved ballmouse prob after conecting
    everything is possible
    home is where your heart is
  4. #84
    Feb 2004
    NYC
    that's cool to hear. I'm just concern for my case since I do have that recognition problem when I return from sleep/hibernation. I'll be watching this thread or a new one you created to record your WIP.
  5. #85
    Feb 2004
    NYC
    any update on your prject hklomann? My fund is almost complete and would really like to hear how's it going.
  6. #86
    Nov 2003
    Germany NRW
    not yet i ll bag you pardon but first have to do a few other things thread will be updated as soon as something new is to say...
  7. #87
    May 2004
    I love the Trimble Lassen SK2 module. I built an interface PCB, it's been operating perfectly. Here is a pic (if I could attach it).
  8. #88
    MySQL Error jcdillin's Avatar
    May 2003
    Miami, FL
    dual serial outputs?
    肚子笑痛了
    S60 Install
  9. #89
    Nov 2003
    Germany NRW
    @jcdillin
    both serial ports of the ublox module can be configured as in or output
  10. #90
    May 2003
    Miami, FL
    very cool
    肚子笑痛了
    S60 Install
  1. Getting Started with GPS
    By grepzen in forum The FAQ Emporium
    Last Post: 09-26-2006, 06:54 AM
  2. Newbie's guide
    By EBFoxbat in forum Newbie
    Last Post: 02-08-2005, 11:06 AM
  3. a new way of GPS
    By brownpage in forum GPS
    Last Post: 08-24-2004, 03:51 PM
  4. Window Tint's effect on GPS signal
    By MoFo in forum GPS
    Last Post: 07-19-2004, 06:08 PM
  5. USB DVD + Radio Tuner + OEM GPS
    By gguy in forum General Hardware Discussion
    Last Post: 02-13-2001, 12:43 PM
