Page 1 of 10 12345678910 LastLast
Results 1 to 10 of 92
Thread: OEM GPS Modules.
    FLAC IntellaWorks's Avatar
    Jun 2004
    NH
    OEM GPS Modules.
    Anyone using OEM gps modules ? Garmin 15L
    I just installed this in my case, plus put the antenna which is no bigger than my thumbnail on the roof. This little guy is super small (I'll try and get pics) & has a strong magnet. This is at least two times smaller than any GPS mouse I've ever had, plus it's WAAS capable. I tested to see if it was working using this great tool:
    GPS testing software
    (at the bottom of the page download: GPS Diagnostics)
    This tool auto detects the GPS unit if you don't know which COM port. Basically I took the pigtail and connected it to my Via Epia's Extra 'internal' COM port or COM2. Then I mounted the OEM GPS in my case and used the tool with the machine booted and it got lock, bam OEM GPS..
    The benefits ?? Well read the stats on this little module, low power (3.3v) WAAS capable and faster lock times..
    Progress [I will seriously never be done!]
    Via EPIA MII
    512MB RAM
    OEM GPS (embedded)
    nLite WinXP pro on
    1GB Extreme III CF card
    Carnetix 1260 startup/ DC-DC regulator
    Software: Still, re-Writing my existing front end in .Net
    FLAC edrex's Avatar
    Dec 2004
    West Chestinghamshire, UK init!!
    Looks interesting. How much was it and where did you get it from? Does the antenna just sit on top of your roof, or is it mounted inside the car?
    Spent so far: $1,755
    Check Out My Work Log for Specs/Pics
    CarPC Progress[!!!!!!!!!!!!!!].....Installation[---------+].....Pastrami Progress[!!!!!!!!!!!!!!]
    Don't mess with Texas.
    It's not nice to pick on retards!
    MySQL Error jcdillin's Avatar
    May 2003
    Miami, FL
    Thats perfect, $90 seems to be the going price without antenna.
    肚子笑痛了
    S60 Install
    n00b 4 life mp3oplecarrier's Avatar
    Dec 2003
    Chatham, UK
    [QUOTE=IntellaWorks]Anyone using OEM gps modules ? Garmin 15L
    Yep, I've been using a Garmin GPS25 for about 3 years now, it's a 5v device but quite similar to yours. If Iwas buying a GPS again I would go for the one you have,they just feel more like you 'made' them than those boring mice you just plug into a USB port!
    Steve
    ....Yes, I know it has a stupid name, those crazy Japanese!
    The land of polar bears and nekkid blonds
    Not quite yet, but I have a GPS25-HVS (6-40V Input) that's going in my install.
    /M
    FLAC Spaghetti's Avatar
    Jul 2003
    Spagcave, in da UK Today's phrase: J'aime Alizee
    [QUOTE=mp3oplecarrier]
    Quote Originally Posted by IntellaWorks
    Steve
    WAAS standard doesn't work over here apparently
    Jun 2004
    NH
    Whole setup
    The whole setup cost about 135.00 but really blows away a USB GPS mouse. These GPS mods were designed for system developers and advanced GPS applications.
    If your looking for a completely "embedded" CarPc then this would be the way to go, its great to hear from others that are using this hardware...
    I think the things I like about it most is that, I'm not using up a USB port I'm using up only 3.3v to power it up, it's smaller than any other GPS device (.75 * .5 * .5) L x W x H and its more capable than the normal USB devices you can buy.
    Via EPIA MII
    512MB RAM
    OEM GPS (embedded)
    nLite WinXP pro on
    That's exactly why I went down that route, I want to keep it as embedded and as "stock" as possible.
    My car (SAAB 9-5 Aero) got a stock "sharkfin" GSM/GPS antenna I intend on using.
    Since most motherboards have an serial port header on the board itself you don't have to make any external connections.
    /M
    New York
    I myself am running the Garmin 15H unit 8-40v or something like that. Works great and definitely recommend it. My only complaint is that it looses satelite lock very easily despite have a strong lock under foilage. But I think I narrowed it down to a poor shielding antenna cable. Will be changing that setup soon. Whats the performance like for you? Just wanna be sure its only me and not others in the same boat.
    Jan 2004
    NYC
    I'm not using up a USB port I'm using up only 3.3v to power it up....
    Im a little confuse here, From the pic I see, how would this mount in the case? Can I mount it some where in the trunk/anywhere, Does a M10K have an "internal" serial port? and how are you getting 3.3v in the car?
    thanks
  1. Getting Started with GPS
    By grepzen in forum The FAQ Emporium
    Last Post: 09-26-2006, 06:54 AM
  2. Newbie's guide
    By EBFoxbat in forum Newbie
    Last Post: 02-08-2005, 11:06 AM
  3. a new way of GPS
    By brownpage in forum GPS
    Last Post: 08-24-2004, 03:51 PM
  4. Window Tint's effect on GPS signal
    By MoFo in forum GPS
    Last Post: 07-19-2004, 06:08 PM
  5. USB DVD + Radio Tuner + OEM GPS
    By gguy in forum General Hardware Discussion
    Last Post: 02-13-2001, 12:43 PM
