Results 1 to 5 of 5
Thread: Hooking up an FM transmitter to Power Supply
    Jun 2004
    I have an FM wireless transmitter that I got from RadioShack (link below) and I want to be able to modify it so that I can power the DC power adapter by hooking it up to the PS.
    What wires do I want to connect this too in order to give it juice?
    Anyone done this? Anyone hooked up neons to a PS? What the best way to have this turn on with the PC?
    Jun 2004
    Mar 2004
    Never tried to wire in a FM transmitter, but I doubt it is any different than other things. You need to find out what the input voltage is for the actual transmitter, which would be the output voltage for the cig. adapter. After that, just need to wire into a HD molex connector, using either 12v (yellow) or 5v (red) and then the ground.
    I did this with my Xenarc monitor power. Hope that helps
    Stank Cheese n8scstm's Avatar
    Oct 2004
    Eastvale, Ca (Near Corona)
    Read the writing on the adapter, where it plugs into the lighter. Cut the end off and strip the 2 wires. Then depending on the voltage connect them to the computers molex. Get a multi meter and learn to use it. They are very handy.
    2.4 celeron
    150 watt OPUS
    micro atx
    xp pro
    tv/radio tuner card
    Dual monitor Radeon
    802.11G Mimo
    xm pcr
    8" Lilliput touch screen
    dual optimas
    battery isolator
    15" screen
    My Truck
    Feb 2005
    I used that product with my old MP3 player and it worked really well for the size of the thing. It is a simple 12V input that you can tap off your PC power supply. I ran a Molex connetor out of the case that had two 12V pins and two Ground pins. Two pins power my Xenarc and the other two pins power my Direct XM box. Works like a charm! The only other power connection I have externally is a 5V+ to a USB hub.
    1999 Nissan SE-L - turbo toy
    1993 Nissan NX - Turbo Racer
    Standalone fuel management (AEM EMS) on both
  1. My low cost, easy to build power supply...
    By SkinnyBoy in forum Power Supplies
    Last Post: 09-27-2006, 06:10 PM
  2. Choosing a power supply now.
    By Osiris in forum Power Supplies
    Last Post: 01-31-2005, 05:51 PM
  3. 350 watt power supply
    By MasterJacko96 in forum Power Supplies
    Last Post: 01-20-2004, 04:01 PM
  4. Alright, Gonna make my own power supply.
    By crazydemon in forum Power Supplies
    Last Post: 01-18-2004, 05:36 PM
  5. AT power supply questions
    By JustAGuy in forum General Hardware Discussion
    Last Post: 07-26-2000, 04:35 AM
