Results 1 to 9 of 9
Thread: Splitting Ground?
    Mar 2004
    Splitting Ground?
    Ok, I want to have one ground wire wired to some type of splitter, then a bunch of other grounds plugged into it. It would be like a distribution block for power, but is there anything I can use?
    Jan 2005
    I think a distribution block would be your best bet.
    Dec 2004
    CT
    you can just use a regular unfused dist. block like you said that will work fine, just make sure you use a low guage wire to ground to the frame, like a welding cable or 0/1 guage wire
    Feb 2004
    Quote Originally Posted by Coeus
    How about a grounding block?
    Here's one example of a grounding block:
    http://www.sd-instruments.com/gb-10.htm
    It's just a block or a strip of conductive metal with screwholes tapped for fastening the ground wires.
    You can use nearly anything, but something made of copper or aluminum would be best.
    My plan for wiring my electronics is to wire both a positive power lead to each device, and a seperate ground wire back to the power supply, with the power supply connected to ground.
    If you don't create any loops, you can't have any ground loops or differentials in ground potential..
    Mar 2004
    Quote Originally Posted by bobs987
    Why such a low guage? I could not use 12 or something?
    Jan 2003
    Ruston, LA
    For your wires coming into it, sure, but depends on the load.
    For your wire from it to ground, use 4 or lower.
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
    Constant Bitrate Maukio's Avatar
    Jul 2004
    Oklahoma
    Or solder em all to a big wire and cover the bare part with heat shrink tubing. That's what I did and works great.
    '99 Accord LX
    Pics of CarPC Setup
    Maximum Bitrate sfay93's Avatar
    Feb 2004
    Omaha, NE
    I would use 4Ga from the dist block to ground and then you should use wire the same gauge as your 12V wires for whatever you are hooking up. You also want to try to mount your dist block in a place where the wire grounding it and the wires running from it to your devices are as short as possible.
    ATVMS.com
    Mar 2004
    short as possible? hmm, i have my Opus ground running from the back to the front.
  1. Replies: 0
    Last Post: 12-02-2004, 01:48 PM
  2. Finding good ground to prevent Ground Loop
    By lookinco in forum Power Supplies
    Last Post: 11-04-2004, 01:23 PM
  3. Turtle Beach Santa Cruz Sound Card GIVES me a ground loop?
    By rmjjensen in forum General Hardware Discussion
    Last Post: 11-15-2003, 07:26 AM
  4. Question: Arise psu: ground, neg, and pos.....?
    By Tony S in forum Power Supplies
    Last Post: 05-02-2001, 07:54 AM
  5. ground loop isolator help
    By digital chaos in forum General Hardware Discussion
    Last Post: 03-11-2001, 01:38 AM
