Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
Thread: ground loop isolator
  1. #11
    Constant Bitrate forevertheuni's Avatar
    Jul 2004
    Quote Originally Posted by ZenerDiode
    and you HU to...and don't forget the power supply ground.
    The Headunit ground wire?
    In a world without Gates and Windows there are no fences or walls!!
  2. #12
    Constant Bitrate ZenerDiode's Avatar
    Nov 2003
    Bay Area
    yep...the headunit ground wire. 95% of the time, the ground that is provided with the plug that goes into your HU is fine...but I've actually seen an install where the guy had to ground the HU to same point as his amp to get rid of the ground loop hum.
    btw...what's your setup again?
  1. Ground Loop Isolator
    By Matthew230 in forum Car Audio
    Last Post: 10-28-2004, 03:11 PM
  2. Replies: 2
    Last Post: 10-28-2004, 02:52 PM
  3. FS: Radio Shack Ground Loop Isolator!
    By mwinkler in forum Classified Archive
    Last Post: 04-11-2001, 11:38 PM
  4. ground loop isolator help
    By digital chaos in forum General Hardware Discussion
    Last Post: 03-11-2001, 02:38 AM
  5. Where does ground loop isolator install?
    By grandamp3 in forum General Hardware Discussion
    Last Post: 09-14-2000, 09:10 AM
