Results 1 to 10 of 12
Thread: ground loop isolator
    Constant Bitrate forevertheuni's Avatar
    Jul 2004
    Portugal,Mealhada
    Is there any way to build a ground loop isolator?
    In a world without Gates and Windows there are no fences or walls!!
    Self proclaimed spoon feeder TruckinMP3's Avatar
    Jun 2002
    Colorado
    Whay re-invent the wheel.
    If you have a ground loop, you should fix it by grounding everything to the same point.
    If for some reason that does not work buy a ground loop.... many are available.... try a search for installs that use them.
    TruckinMP3
    Read the FAQ!
    Jul 2004
    Portugal,Mealhada
    I justed wanted to know how the thing works
    Jun 2002
    Colorado
    That is a different question.... Not sure what parts are used.... sorry.
    TruckinMP3
    Read the FAQ!
    Constant Bitrate ZenerDiode's Avatar
    Nov 2003
    Bay Area
    just filters to block frequencies over a certain value....you definitely don't want to use em if you want to retain sound quality. they tend to cut off the highs and lows to get rid of the ground hum
    Stank Cheese n8scstm's Avatar
    Oct 2004
    Eastvale, Ca (Near Corona)
    Its a ferrite core magnet with the wire that you are isolating wrapped around it.
    2.4 celeron
    150 watt OPUS
    micro atx
    xp pro
    tv/radio tuner card
    audigy
    Dual monitor Radeon
    802.11G Mimo
    xm pcr
    dvd
    gps
    8" Lilliput touch screen
    IGuidance
    dual optimas
    battery isolator
    15" screen
    My Truck
    Jul 2004
    Portugal,Mealhada
    Quote Originally Posted by ZenerDiode
    I think that's acceptable...more than earing the sound of the engine
    Jan 2004
    the best thing is to get 1 and install to alternator thats the most likely cause of your noise
    alot of old cars used to have them fitted to the outside of the case
    allso cheap car radios have them its the big black block with the power supllys going though them
    Jul 2004
    Portugal,Mealhada
    alternator
    ..thing is..how do I do that . By the way since I installed my carPC the sound of my headunit(radio) with FM doesn't work pretty well . If my car is stopped it's just make noises.and if I shutdown the computer the sound comes. The ignition 12V wire is the same could that be it?
    Nov 2003
    Bay Area
    Quote Originally Posted by forevertheuni
    yeah, i thought that was acceptable too...until I tried it out. it was actually unlistenable to me.
    btw...it really sounds like to have a grounding problem. try to find a bare metal spot to ground both your pc (including various metal pieces like the backing plate) and you HU to...and don't forget the power supply ground.
  1. Ground Loop Isolator
    By Matthew230 in forum Car Audio
    Last Post: 10-28-2004, 03:11 PM
  2. Replies: 2
    Last Post: 10-28-2004, 02:52 PM
  3. FS: Radio Shack Ground Loop Isolator!
    By mwinkler in forum Classified Archive
    Last Post: 04-11-2001, 11:38 PM
  4. ground loop isolator help
    By digital chaos in forum General Hardware Discussion
    Last Post: 03-11-2001, 02:38 AM
  5. Where does ground loop isolator install?
    By grandamp3 in forum General Hardware Discussion
    Last Post: 09-14-2000, 09:10 AM
