Originally Posted by IntellaWorks
expensive antenna...
Originally Posted by woeful
Software - Mappoint Active X embedded into my front end.
Antenna - Antenna
I haven't had much problems yet, but my front end isn't fully completed.
Progress [I will seriously never be done!]
Via EPIA MII
512MB RAM
OEM GPS (embedded)
nLite WinXP pro on
1GB Extreme III CF card
Carnetix 1260 startup/ DC-DC regulator
Software: Still, re-Writing my existing front end in .Net
Yea, its the smallest antenna money can buy and has a strong magnet. It's like .5 * .5 * 1 (inches)Originally Posted by woeful
Via EPIA MII
512MB RAM
OEM GPS (embedded)
nLite WinXP pro on
Do you mean the wire like the one in the attached pic, or are you talking about a different wire?Originally Posted by hklomann
Spent so far: $1,755
Check Out My Work Log for Specs/Pics
CarPC Progress[!!!!!!!!!!!!!!].....Installation[---------+].....Pastrami Progress[!!!!!!!!!!!!!!]Don't mess with Texas.
It's not nice to pick on retards!
thats it yes
everything is possible
home is where your heart is
That link to the antenna isn't really pointing to an antenna, it's an integrated antenna/revceiver from garmin, which comes in different flavors (USB/Serial/TTL)...
sure it wasn't this one: http://www.gpscity.com/item-garmin-g...enna/ga27c.htm![]()
Good call, I was rushing and not truely paying attentionOriginally Posted by JC-S60
Via EPIA MII
512MB RAM
OEM GPS (embedded)
nLite WinXP pro on
Then, like I said, save yourself $20!Originally Posted by hklomann
I have the Glisson antenna from:
http://www.gpsgeek.com/page3.html
It's cheap ($20.00) but works great!!!
Intella:
From what I can tell you only use 4 of the 8 wires that come off the 15L, right? 2 for power that I'll be getting off usb pins, and 2 going into the COM port 2. Is that correct, and if so, what are the other wires for? I will be (hopefully) installing this tomorrow if I can find something to use to connect the wires to the pins. Any suggestions would be great.
Thanks again for the excellent writeup (which should really be a sticky so more people will know about the OEM route).
Cheers.
