Page 6 of 7 FirstFirst 1234567 LastLast
Results 51 to 60 of 68
Thread: OEM GPS mod. Writeup + Pics
  1. #51
    Feb 2005
    Quote Originally Posted by JC-S60
    That link to the antenna isn't really pointing to an antenna, it's an integrated antenna/revceiver from garmin, which comes in different flavors (USB/Serial/TTL)...
    sure it wasn't this one: http://www.gpscity.com/item-garmin-g...enna/ga27c.htm
    you game me the wrong link intel, so i bought the one from this link. it's big.
  2. #52
    FLAC edrex's Avatar
    Dec 2004
    West Chestinghamshire, UK init!!
    Quote Originally Posted by woeful
    This is the one you probably want: http://www.gpscity.com/item-gps-city...micromouse.htm
    Thats the same one that I have that is in the pictures.
    Spent so far: $1,755
    Check Out My Work Log for Specs/Pics
    CarPC Progress[!!!!!!!!!!!!!!].....Installation[---------+].....Pastrami Progress[!!!!!!!!!!!!!!]
    Don't mess with Texas.
    It's not nice to pick on retards!
  3. #53
    May 2004
    is it possible to add a bluetooth module to the unit?
  4. #54
    Constant Bitrate cyberlancer's Avatar
    Feb 2005
    Gallarate (VA) - Italy
    why not using white wire
    well, i connected my GPS 15L-W to my mobo and everything run well, just:
    could anyone tell me the reason why we are not using white wire to connect to serial ground (pin 5 on com2) as shown in garmin PDF?
    thanx.
  5. #55
    Dec 2004
    Quote Originally Posted by integramodder
    Quote Originally Posted by IntellaWorks
    Yea, another reason is that the bulk of the electronics is inside my car instead of out in the weather...
    Also my GPS unit maintains a lock for up to 21 days un-powered.... your USB mouse doesnt..
    This GPS mod takes a less amount of power and is WAAS capable... At the time I was doing the initial research there were no WAAS USB gps mouse's...
    The antenna that goes on the roof of my car is less than a quarter of the size of the smallest GPS mouse, so its more of a stealthy look...
    When you say gps mouse are you actually refering to the gps mice that are sold or the general all in one package?
  6. #56
    Hi all. A few years ago when I was into this whole carpc thing much more I went and bought up some OEM gps stuff, got it to work in my house, and then promptly put it up to never use it again. The module I got to work was an sveesix module that can be seen here: http://www.rodaxwireless.com/images/jpg/trimbleCM3.pdf
    with some antenna that I have no clue what it is (I can snap some pics and attempt to identify it for you if you want). I also have another OEM gps module that I can't remember what it was (I can attempt to identify this too) as well as 2 trimble antennas. One of the antennas needs a connector and the other one doesn't fit the sveesix module (the reason I ended up buying the third antenna).
    If anyone is interested in this stuff I am willing to let it go really cheap just to keep from having it sit forever and eventually be thrown away.
  7. #57
    MySQL Error jcdillin's Avatar
    May 2003
    Miami, FL
    I responded to your thread in the FS forum
    肚子笑痛了
    S60 Install
  8. #58
    Raw Wave RoyN's Avatar
    São Paulo, Brazil
    I want to improve my reception, but this stuff is kind of scaring me away...
    Is there a kit that comes with all connectors and stuff that I can plug to the serial header in my MOBO, and plug into a antenna externally?
    Or is there a GPS mouse that is external-antenna capable that I can use?
    Or a kit that just has everything required?
    Please, I live in Brazil and the satellite signal is awful here in the dense city, so I really need something better than my bu-303...
  9. #59
    FLAC aoLhaTer's Avatar
    Mar 2003
    Rohnert Park, CA
    I just went ahead and bought the 15L Wired and a Hercules antenna
    One thing Im not clear on is the persistant power to the device. It was mentioned that it has a battery in it thats good for 21 days. Is this a rechargable battery? Im assuming it has be...
    Just would like someone to verify so my minds at rest
  10. #60
    May 2003
    Miami, FL
    yes it is
    肚子笑痛了
    S60 Install
  1. Stealth OEM install in MR2 Spyder - Magazine coverage!
    By silencery in forum Show off your project
    Last Post: 07-31-2008, 04:15 PM
  2. Sony XA-300 mod pics?
    By tom2112 in forum General Hardware Discussion
    Last Post: 10-27-2004, 03:48 AM
  3. Replies: 9
    Last Post: 10-25-2004, 01:34 AM
  4. Some mod pics of Remote and D Link radio
    By gospeed.racer in forum General Hardware Discussion
    Last Post: 01-14-2004, 03:10 PM
  5. pics of my pioneer slot DVD window mod =)
    By moahdib in forum General Hardware Discussion
    Last Post: 04-30-2002, 05:10 PM
